My glow plug light was coming on and strange intervals and never did illuminate when I turned the key so I replaced the relay and the controller and, presto, the light comes one when the key is turned and hasn't come on when the tractor is running. I've searched and seen a post or two about my question but no answers. When I turn the key to heat the glow plugs the light goes out in about 5 seconds. Now, it hasn't been below 40 F when doing this so I don't know if ambient temperature would affect that time. However, one thread suggested a bad glow plug controller (it was new) that was replaced and his issue was resolved. How long should the glow plug light illuminate? Is it temperature dependent?
I'm wondering if the glow plugs aren't working properly. I did turn the key and feel the glow plugs but never felt anything warm. However, the light goes out fast so it may not be heating up properly which, I'm guessing, could be due to bad glow plugs. I found aftermarket plugs pretty cheap at http://www.owossotractorparts.com. All four for $76 shipped. That's cheap enough to just replace them. I also see part 16415-83040 which is a temp sensor for the glow plugs as best I can tell. I went ahead and ordered that, too. We'll see if these things help. I'm figuring new glow plugs will be good to have regardless given winter coming up and the fact that they were on for quite a bit with the bad relay/controller.
Any other advice?
Any other advice?
