What attachment available for LA524 FEL ?
bandaidmd
B2620 w/LA364 FEL ,BH65, ssqa , 1982 B8200E w/BF300FEL
May 19, 2013
603
Middle of DELMARVA
I have a LA524 for my L3800.
I was wondering what attachments are available to swap in and out on the quick release?
I searched Kabota's website, I would think there is a list somewhere but I can not find.
I am particularly interested in something that can do some digging like a Tree Spade.
http://www.everythingattachments.com/Implement-Video-Demonstrations-s/2999.htm
Do you have the skid steer quick attach on the loader? If you do then any attachment thats listed as a universal skid steer mount will work.
tsafa
Kubota L3800, FEL, F550 Dump, 10K Trailer
Nov 3, 2013
152
Tobyhanna, PA
I have not heard of this. I just have what came standard with the LA524 plus bucket. I will start looking into it.
I was hoping Kabota might have a list of attachments.
UnionMan
M5-111HDC12, L3800 HST , RTV-X1100C, SCAG TigerCat 61" Kawi FX Motor
Aug 21, 2013
104
Warrenton, VA
Where the Arms attach to the bucket do you have Pins or do you have two large handles with springs attached? The picture below shows the quick attach. If you have what looks like the picture, then your options are endless.
tsafa
Nov 3, 2013
152
Tobyhanna, PA
I have what you show in the picture. Happy to hear I have endless options.
Do they make a tree spade the will fit my loader?
Perhaps a bucket with teeth?
5,475
For the skid steer type loader attachment they make anything you would ever want.
Search for "skid steer attachments";)
How about a tree spade with teeth!:D
tsafa
Nov 3, 2013
152
Tobyhanna, PA
The Tree Spade looks awesome.
The only thing that I am not sure... and sorry if I am not understanding the obvious.... will that Tree Spade fit on my FEL or do I need some adopter? My FEL looks exactly like the one posted in the earlier picture.
I really like this one:
http://www.ebay.com/itm/NEW-STUMP-B...d=100005&prg=8427&rk=3&rkt=5&sd=281175901148&
Vtmaple
L2250
Nov 7, 2012
South Strafford, VT
tsafa, is there any chance you could get a model number or part number off from that SSQA you have on that pallet in the picture? Thanks, Dan
5,475
Sorry missed this earlier,
Yes any skid steer backing plate (SSQA) attachement will work for you, that is the joy of it. Just avoid the MINI skid steer attachments as they are narrower!
tsafa
Nov 3, 2013
152
Tobyhanna, PA
tsafa
Nov 3, 2013
152
Tobyhanna, PA
Thanks for verifying and for warning me about mini-skid steer attachment.
I have been seriously thinking about this attachment:
http://www.northerntool.com/shop/tools/product_200612297_200612297
Not too expensive and not too heavy for the LA524 at about 140 lbs. I saw some others weighing in at about 300 lbs but I think that is over-kill for a loader with a rated lift capacity of 840 lbs and max lift capacity of 1.200 lbs.
The only issue I foresee is visibility. This attachment would seem to allow the FEL to do a lot of backhoe type work up to a limited depth of 4 feet... but I am thinking it will be hard to see what I am doing over the engine. Any thoughts on this???
5,475
I think you will be surprised how easy it is to see it when it on.
I've never really had an issue running any buckets on my loaders.
Is it as easy as a skid steer.. well no but easy enough, if it does pose a visibility problem put a couple of flags on it, like they do with snow plows.;)
tsafa
Nov 3, 2013
152
Tobyhanna, PA
Thanks for that great advice!
Vtmaple
L2250
Nov 7, 2012
South Strafford, VT
My mistake tsafa,I guess it was Unionman who posted the picture of the quick hitch sitting on the pallet, thought maybe if it was right there it might have a model or part number listed on it. If someone with this style SSQA could post the model and or part number off from it, it would be greatly appreciated, Thanks, Dan
bandaidmd
May 19, 2013
603
Middle of DELMARVA
That looks like a factory Kubota hitch in the picture, call the sales department at your dealer for info ( not the parts counter).
To the original poster,
As you already noticed the weights on some attachments designed for the SSQA are pretty high and that's because a true skid steer has enormous lift capacity and hyd. flow.
Even thou our tractors have a compatible mount keep that in mind when choosing attachments.
Here's some good dealers for implements , there are a lot more but i have personally bought from these and can attest to there service.
http://stores.palletforks.com/StoreFront.bok
http://www.everythingattachments.com/?Click=3449
tsafa
Nov 3, 2013
152
Tobyhanna, PA
Yeah... I thought something was out of place when I saw 500 lb skid steer buckets.
JLMullins
L3800 Gear 4X4
Feb 25, 2014
14
TN
What if you don't have that quick release like in the pics? Is there something you can do?
Thanks,
Frist Time Kubota owner L3800DT
5,475
You can add the SSQA adapter to your loader so you can use anything out there.
Otherwise your stuck with Kubota and a few after market offerings, and stuck beating pins in and out.
