b7100 front pto shaft?
Max Power
b7100
Oct 4, 2013
Ottawa, ON
Hi all! I just bought a b7100 and noticed the other day that there is what looks like a PTO shaft sticking out the front. It has tighter grooves than the rear PTO shaft. There is no way that I can put a an implement shaft to this because the rad is in the way. What is this mystery shaft? Is it for a pulley? How's it activated?
BadDog
B7100D TL and B2150D TLB
Jun 5, 2013
579
Phoenix, AZ
It is direct drive (unlike most rear PTOs), and is usually used with a front auxiliary pump for a loader. Mine is that way. Probably for other things too, but none come to mind right now.
kubotasam
Apr 26, 2010
1,211
135
Alfred Maine
As well as hydraulic pumps for loaders like Baddog said. Older B7100's used the front pto shaft to drive a belly mounted mower, also snow blowers were powered by the front shaft.
Max Power
b7100
Oct 4, 2013
Ottawa, ON
Cool. Thanks. So it just turns all the time? Also, what size of pump do I need to run a loader?
AOW162435
'25 LX2620 / '79 B7100 / '03 JD x595
Jun 16, 2023
196
Ellicott City, MD
Dusting off this thread to see if anyone knows where to purchase a simple sleeve / female adaptor for this splined shaft.
Andreas
3,382
