Hello everyone.
Okay, all is well again.
Last night, I added a dose of Bio Kleen to my suspected to be contaminated fuel. Today, I drained said fuel and cleaned the tank out the best I could. I cleaned the tank by making a flexible mop out of an old fishing rod and some shop rags that are not supposed to leave lint. I did not go nuts mopping the tank; just a couple passes. In order to drain the tank I removed the front line filter, which had to be replaced again anyway, and used compressed air to pressurize the tank. This saved some time.
I refueled the tractor with on-road diesel from Sonoco that I treated with a dose of Bio Kleen, Power Service Diesel treat, and Sea Foam.
I then installed new filters, bled the system, and let the tractor idle for some time to let the Sea Foam do its thing. After about 30-45 minutes of idling, I took the machine for a few laps around the yard. All seemed well. In order to not destroy the lawn, I took the tractor around the neighborhood, up and down hills to put a strain on it. Again, all was well. So I put my deck on, cut the grass and everything is fine.
Lesson learned:
Treat every tank of fuel.
I personally will never again use off road diesel in my tractor. I was taken to the diesel tanks where I work and shown by on of the mechanics the difference in the filtration they use on the off road tank versus the on road tank. Apparently there is a difference that is more significant then just some dye. Because I use so little fuel a year, it is worth it for me to use a cleaner fuel to keep my tractor in good running order.
Replace fuel filters at least once a year.
Thank you all for your help troubleshooting this problem. I saved a lot of time and headache with your tips. Really, very cool. Thanks again.
Matt
