How do you remove Oil Seal
On a L275, how do you change the main Oil Seal Part #19202-04460, (part #11 in schematics), located behind the flywheel that holds the engine oil in the engine? Found a few drops of oil on the bottom of it when I removed the flywheel to replace the pilot bearing. I keep finding one more thing as I keep digging deeper into this, any thing else I should check? From the flywheel back, everything is in various stages of disassemble so now is the time to do WHAT EVER needs to be done.
This is related to the following thread:
http://www.orangetractortalks.com/forums/showthread.php?t=10866
Attached pic and schematics.
Thanks for any and all help.
http://kpad2.kubota.co.jp/kpad2/Par...d=&figNo=005000&himban=01123-50828&dispType=2
