b4200 diverter valve issue
jmielnicki
b4200
Oct 14, 2026
21
MA
I have no fluid going to the loader valve when valve is switched to it. the 3 point is operating when switched to that. The suction filter was recently cleaned as it was caked up. do I possibly have a clog in the valve? how easy is it to take apart and clean?
Thank you for any info that can help
7,378
How did you determine there is no fluid going to the loader? Do you have cc quick connects on the loader hoses?
Pictures would be helpful.
jmielnicki
b4200
Oct 14, 2026
21
MA
I can take pictures in a little while
I also opened a line to the bucket piston to see if fluid was going through and nothing
7,378
Fluid only fliws when the cintril valvd is operated. Did you operate the valve?
What i am suggesting is one or more of the quick couplers is not fully connected or has stopped working.
Eliminate the quick coupler on the feed to the loader and check again.
jmielnicki
b4200
Oct 14, 2026
21
MA
ive never taking the selector valve apart just dont want any surprises looks like only 4 bolts in the front but not sure whats behind
7,378
Post a picture of your valve. Most are nothing more than a ball valve and nothing to clog up. Some are needle valves. I think it is more likely you are not getting it to open
7,378
That valve switches the flow from 3 point to bucket
Have you used thst valve before?
I believe I had that same valve on a B7200. It was not a diverter. Flow went into the 3pt cylinder and then out to the implement. The 3pt lever had to be locked in the full up position to use the aux port and the lever guide had a notch for that purpose.
jmielnicki
b4200
Oct 14, 2026
21
MA
Havev I ou used thst valve before?
I’ll put 3 point all
The way up and try that
Thank you
I have a feeling it’s something simple im overlooking
