Ole 68 Longhorn
Outnumbered
Kubota L3901, FEL, BB1260, RCF2060, FDR2572, Forks, 55" Grapple, 5' Tiller .....
Oct 26, 2019
275
510
Moseley, VA
I have been working on this for the last 6 months. My FIL purchased it new in 68 and used it strictly for hauling cattle and farming. Ole 250cid 6 with 3 on the tree whit a whopping 64k miles. Fun project for an old retired guy. IMG_4826.jpeg
BAP
Dec 31, 2012
3,208
1,320
What a Beautiful restoration job on a Great truck!šŸ‘
11,292
I learned to drive a 1968 C20 when I was 7, used it for all the ranch duties.
It was a custom factory build that the guy that ordered it turned it down when it showed up at the dealership because it didn't have a couple of the features that he wanted on it.
dealership sold it for cheap to get rid of it.
V8 327 4 speed that truck was always super peppy.
JohnDB
M4500DT with FEL, back blade, Someca K28 hay mower, drag broom, post driver
Jun 9, 2018
565
190
NZ
In my imagination, a 7 y.o. with V8 327 under the pedal, leads me to think that there could be some interesting stories lurking there... care to share with us? :)
11,292
Oh there was quite a few over the years.
Some of my antics could still have people looking for me! :whistle:
And yes I got myself in some serious dodo! 😜
Killer Bee
110
177
Show-Me State
nice looking truck, and great job on the bed wood!
for those that don't know, 68-72 chevy/gmc longhorns had a 6" longer wheelbase of 133" and the beds have a 6" extension making them 8' 6" overall. the bed is extended at the front where seam is visible, they weren't filled at the factory. the trim if optioned, has a 6" extension at the rear of the bed so those seams are not in the same place.
all of them had wood bed floors, no factory stamped steel longhorn beds offered.
they were all c20 or c30, no factory half ton or 4wd offered.
production numbers were fairly low. not necessarily rare but definitely less common.
growing up on the the family farm, I learned how to drive in dad's '65 chevy c20 283 4spd. still have the truck and the farm. just mowed that lane yesterday where this picture was taken years ago.
my first truck that I bought was a '68 gmc c20 350 3spd on the column. bought from a fellow sailor when we got back from desert storm. drove it all over ca and most fun driving was in sf while I was at c school on treasure island, even drove it down lombard st.
this is in front of the barracks on treasure island. along with the navy training center, now all long gone.
along the way I have acquired two '71 longhorns, still have both out on the farm.
'71 c20 longhorn 350 auto
wood bed was shot so I bought a mar-k kit, finished it and put it all back together. I use it for chores and it still looks like a coffee table in there.
'71 c20 longhorn 350 4spd
also needs a bed, old wood completely stripped. I already bought the same mar-k bed wood kit I used in the ocre truck, just need to muster up the will power to do another one. that's a big job, about two weeks with multiple coats of epoxy and spar varnish and all the fitting and finagling to get everything straight and square.
sorry op for the intrusion, but these are one of my favorite hobbies that I can actually get work out of. šŸ»
4,035
2,485
We had the opposite - '61 C10 Apache step-side 6 cyl (no oil filter), 3 on the column, left side mirror only, single tail light (no turn signals), heater, no radio. Previous owner had installed overload springs and 8-ply mudgrips on the rear. I'd stop at the feed mill for a ton of feed and waddle on out to the farm. Oh, and it was pale yellow.
Outnumbered
Oct 26, 2019
275
510
Moseley, VA
Killer Bee, you definitely are familiar with the ole C10/20/30's When researching this one it looks like 68 was the first year of the Longhorn and from what I can find it looks like there were approximately 1902 made that year. As you mentioned the wood bed definitely takes some patience. I found the white oak on craigslist and took a couple 4 pack of a good hazy IPA over to a former coworker that has a nice wood shop. Came out with all of our fingers and some nicely milled boards. Then comes the sanding and finishing and then all the nuts and bolts while trying to square everything back up. I found the ratchet straps to be my friend. šŸ»
Outnumbered
Oct 26, 2019
275
510
Moseley, VA
It's funny you mentioned the factory order by another guy. That's the same way my FIL purchased this one. According to my FIL it was originally order for a contractor and then they did not pick it up for one reason or another. :giggle:
4,035
2,485
Interesting trivia, I'm not sure it applies to the Longhorn. In 1970, and maybe a couple more years, Chevy made two 400 ci pickups, a 400 ci small block and a 400 ci big block, which was actually a 402, 396 bored 0.030" over. I think the badging was exactly the same, and I don't know if they did this with other vehicle lines.
Killer Bee
110
177
Show-Me State
I know a little bit about this era of gm trucks, short reply...
first 400 sbc factory available in a gm truck was 1973, beginning of square body series.
1973 was also the first year bbc were factory available in k series 4wd gm trucks.
first 396 bbc factory available in a gm truck was 1968.
1970ish factory available bbc truck engines went through a murky transition through 396/400/402 often with badging inconsistent with actual displacement.
this was largely due to the adaptation of engines previously offered in passenger cars, later to light truck applications.
several different engine plants and truck assembly plants around the country also contributed to those inconsistencies.
would need more time for a detail report šŸ»
Killer Bee
110
177
Show-Me State
I believe so, '68 being first year of longhorn. first year models are always cool! and that sounds about right off the top of my head for production numbers of longhorns, if I recall correctly, through '72 annual production numbers were only 4 digits.
nice job milling your own bed boards. I bought pre-milled pine for utility, same as gm did and I wasn't up to the task of creating the milled edge pattern for the straps.
I've seen others that milled their own with similar results to yours. you and your buddy did a great job! and the oak is beautiful, especially for a 'retired' truck.
I may do similar with my dad's '65 but like he would have said, everything on the farm earns its keep or no use for it. :LOL:
rest of your truck looks great as well, nice work! šŸ»
btw, I have a couple of k burbs too. 😁
4,261
Well…. I’ll just Have To jump in with my FORD story! LOL
I found a gov’t-green ā€˜51 Ford F-3 sitting on a lot that had been a U.S. Agriculture truck with a 1/4ā€ steel bed. It had a U.S. Ag shield on the glovebox door. That entire truck was H.D. steel. Six cyl, 3-speed on the column, 6-Volt POSITIVE Ground batt under the pax floorboard. The engine was a new AER rebuild, and I paid $150 for it.
Drove it for a couple years and then let my numb-nuts brother talk me into selling it so he could borrow $150.
Apparently I was just as stoopid as he… ā€˜cause I did it.
(not the actual truck…just a pic of a ā€˜51 F-3)
11,292
This one will poach your brain:
GMC's own V8 was the 637-cubic-inch (10.4 L) unit, which was essentially a 478 V6 with two cylinders added. It shared the 5.125 in Ɨ 3.86 in (130.2 mm Ɨ 98.0 mm) bore and stroke and used a single camshaft. It was manufactured in gasoline and diesel versions, and was the largest-displacement production gasoline V8 ever made for highway trucks. The GMC 637 V8 was produced from 1965 to 1973.
I've seen and worked on one of these beasts, they where quite the sight.
