Best Hand Pump for a Five Gallon Pail of HST,oil
William1
BX25D, JD X754 AWS Mower
Jul 28, 2015
1,479
671
Richmond, Virginia
I'm so done with quarts. Tired of spilling gallon jugs. Time to man up and use cheaper five gallon pails and a hand pump
Looking for the best pump. Meaning one that the lid 'seals', the pump strokes produce a measured amount and is just an all around good tool. Willing to pay the price for top shelf quality.
Don't need electric as it is a once every three years job, a little exercise is good, so they say.
Just want a good one with 'No Regerts'.
ayak
L3301 HST
Feb 16, 2018
788
1,302
WV
I wouldn’t say the lid seals tightly, but I use this on my SUDT-2 5 gal pails:
3,149
I have one that went into the pour spout of the bucket. It screws onto the spout or into the spout opening. I can’t recall but it worked well and could be removed to reseal the bucket or left in but didn’t really seal the bucket.
I haven’t used it much but it did pump fairly fast and cleanly.
You might consider getting a siphon version and setting the oil pail up above the fill port and just letting the siphon flow. You could then measure out the oil into the pail so you know exactly how much you are adding.
I think most of these pumps can be adapted to the spout of a bucket, but I can’t figure out what size the spout of the pail is.
William1
Jul 28, 2015
1,479
671
Richmond, Virginia
Only one of you guys has a actual recommendation? I figured a fist fight would of broken out with 'whose recommendation was best ' by now!
#40Fan
656
484
Cheap from Amazon is what I would recommend. I have two that I use regularly, and they look just like the first one in this thread and run around $35.
hedgerow
487
477
Malcolm NE
I have two of the LuMax brand pumps and they have been good pumps. I bought them at a farm store years ago. I don't use them a lot but there handy when I need them.
5,551
When I was "wrench'n" for a living, I bolted a used "engine oil pump" to the top of a 5 gallon pail and used my cordless drill to power it.
Never needed a "hand cranker" after that. 🤷‍♂️
