Drying / compacting mud
Gaspasser
L6060, FEL, forks, BB, rake, snowblower, KX033 mini-ex, dump truck, splitters.
Dec 16, 2023
473
763
NH
sweetbreezefarm.com
I have 100 feet to go to finish a road for water well driling access. I've already built a proper 170 foot compacted crushed stone driveway to the future house site which will be permanent. Expensive and time consuming. The driller wants the last 100 feet, which is currently dirt, leveled and compacted to be "stoned" as well. It consists of some clay and muddy soils which don't compact well with a plate compactor. This last 100 feet will be the actual house site which will be dug up and excavated for a foundation so any work /stone done will be removed/wasted. The well will be positioned at the end of this run with the house between the well and permanent driveway.
I really don't want to spend time and funds on a project that that will be dug up. Stone runs $1000-1500 for a 4 inch layer of the required area, and that may not be enough for the 80,000 lb load of the rig. Anyone else have any experience with "jumping jack" compactors or using quicklime or hydrated lime to harden the soil for rig access? Would dry sand or cement dust harden the soil sufficiently? Any other ideas? Please help me save my back and bucks.... thank you..... 4889.jpg
Motion
Kubota MX5100HST/FEL
Aug 17, 2020
586
338
Mandeville Louisiana
Dry sand might be the most cost effective, you'll still need the stone, I'd suggest laying the sand and crowning the road before stoning. The drilling rig should be one in, and one out try not to start the ground pumping. Immediately after the well installation remove the stone from the house pad area and stash it for later use dressing the remaining road as it gets compacted. Again, keep it graded and crowned. Also, if there's a need for culverts, water, utility crossing, etc. install them now.
Bee-Positive
Nov 16, 2022
1,176
1,087
Amsterdam, NY
Not sure if you could rent them for less than your budget but have you looked into crane mats or rail road ties? Put them down - pick them up.
Gaspasser
Dec 16, 2023
473
763
NH
sweetbreezefarm.com
What Bee said rent some Swamp Mats as we call them. I think United Rental has them.
Thanks guys. Great ideas. I am putting some sand down and will look into the swamp mats. Will have to compare costs/labor stone vs. mats. Need 11x40 pad for rig setup and then path to pad site from permanent stone drive. Will post on progress.
3,148
Perhaps you should contact the person that is responsible for the house foundation design and ask them what they need in the area where the house will be placed. Then you can install that now for the well drilling and just leave it in place and build the foundation over it. Thus you are not buying material that will just be moved out after this. (I assume the house foundation only covers a portion of this drilling pad but the stability of the house foundation will be needed for several feet around the foundation perimeter.)
Caden
1979 B7100
Apr 16, 2026
329
188
Perhaps mats would be a good temporary solution, as @Bee-Positive suggested.
IMHO there is no way to make a good driveway over clay. The clay needs to be scraped away first.
Even if you gravel over it, the clay will eventually ooze through and resurface.
11,238
Road cloth!
Especially where it's going to be a permanent drive, or parking.
Bee-Positive
Nov 16, 2022
1,176
1,087
Amsterdam, NY
Not true.
I built on a lot that's nothing but clay - little did I know when I bought the property - nice view though.
We dug down and put in road cloth as North Idaho Wolfman suggests, then laid layers of appropriately sized stone over that, hasn't moved in 18 years. Have even had multiple trucks deliver 20+ tons of top soil or stone at a time with no ill effects.
Now if you wonder 18-24" left of the driveway then you've got major problems! We have a natural spring off the hill that runs along the whole length of left side of the driveway, VERY SOFT!
Gaspasser
Dec 16, 2023
473
763
NH
sweetbreezefarm.com
Thanks all. Did use geotextile on the 170 feet of the part that will be permanent to the eventual house site. This branches off from the original 900 foot driveway to the public road ( also geotextile and 1 foot deep gravel stone base. ) The house won't be started until 2027-28 and will require a below grade full basement foundation (NH winters). Hence the desire to not spend a fortune on stone that will be dug up. So here's what I did. Got bank run sand and coated over the wet clay spots. Plate compacted in 2 passes. Compacted further by repeatedly rolling my 1 ton dually mason dump truck fully loaded with stone ( 16,000 lbs gross weight). Did order one triaxle load of 3 inch dense grade to be drop spread ( about $550 for 22 tons) arriving today (Thursday). Will compact the approximately 4 inch deep layer The local United Rental has 12 4x8 "poly mats" which can tolerate 80k lbs pressure. Placing 2 side by side lengthwise along the tire path gives me 48 feet coverage which I can use over any remaining wet/muddy spots. 1 week rental of mats at $51 each = $612. So sand, stone, mats combo will cost about $1200. Already spent approx 3k on stone for the 170 foot extension not counting my labor. Here's hoping this all works and we get a decent gpm flow rate well for the effort. Thanks for all the helpful advice. Will update as events warrant.
Gaspasser
Dec 16, 2023
473
763
NH
sweetbreezefarm.com
Did the math and ran scenarios among all the options: sand, stone, mats, corduroy, quicklime / hydrated lime, etc. Considering the time and labor involved with these options it turns out biting the bullet and just getting 2 loads of stone for $1100 was tbe quickest, most efficient way to get this done. So finished 44 tons today. Unfortunately, compactor gas tank developed a leak so had to settle for mini-ex and dump truck compaction. Should be sufficient to meet well rig requirements. So, look for my thread on removing the clutch and pulley wheel on the HF compactor ( I bought replacement engine) lol. Thanks all.
BAP
Dec 31, 2012
3,199
1,315
You want to make sure that you have extra rock or mats where the well drilling truck is going to be parked. Between the vibrations and the fact that the truck is going to be on jacks limiting the ground contact area, it is going to take extra to support the weight and keep the truck from tipping.
Gaspasser
Dec 16, 2023
473
763
NH
sweetbreezefarm.com
Great suggestion. I'll leave a load of stone in truck for the driller to use. Thanks.
Gaspasser
Dec 16, 2023
473
763
NH
sweetbreezefarm.com
Well, proof is in the pudding. Despite 3 days of rain (nor'easter), the well road access held up to the drill rig brought up this afternoon. No significant sinking. Not bad for an amateur. Drilling starts tomorrow. Here's hoping they hit big water flow at a shallow depth. Paying by the foot. Typical depth in area is 300-400 feet.
Bee-Positive
Nov 16, 2022
1,176
1,087
Amsterdam, NY
Awesome good news.
Our well goes down 385, they hit water at 340 and kept drilling. I ask why since I too was paying by the foot. They said for reserve/storage. We had a drought a few years back, our neighbors wells went dry but ours didn't, so I guess it was worth it.
11,238
My drilled well is 115 feet, static water is 25 feet and 25 gallons per min
Our sandpoint well is 16 feet and 15 gallons per min
Neighbor is 300+ feet and 5 gallons per min
Just up the road they are +900 ft and less than 2 gallons /min
It's all over the board around here.
Gaspasser
Dec 16, 2023
473
763
NH
sweetbreezefarm.com
Yep. Luck of the draw. Closest neighboring wells within a few miles range 150-600 ft. Our site near top of hill at approx. 1700 feet elevation. Typical NH bedrock water contains manganese and arsenic, sometimes radon. So fingers crossed. But need this if we are ever going to build/farm there. Septic site plan is approved and staked out. Probably won't have enough time to get that in before winter. Family member medical issue has me traveling out of state frequently so projects have been delayed. There's always next year. Thanks to all on the forum for the advice and encouragement along the way. Have learned so much here and it is greatly appreciated.
Gaspasser
Dec 16, 2023
473
763
NH
sweetbreezefarm.com
508 feet to water with 5.5 hours of drilling. 4.5 GPM. Will be hydrofracking in morning to try to increase yield.
5,540
Wow...that looks expensive!!
I was told our cottage well is at 325 feet.
We are located about 1/2 mile (as the crow flies) from lake Huron.
Legend has it that they hit water at 80 feet, but "code" is 90 feet, so they had to keep drilling????
Not sure how true that is, but the neighbors built the joint, and thats what they swear to. 🤷‍♂️ 🤷‍♂️:cautious:
Good luck!!!
