Oh wait! Now I know what you mean! The lever in the rear to push or tow the mower…I have a Z422 and I’ve never figured this out either!Hey I've got a 2017 Z421 and the right drive tow lever moves freely but will not disengage the HST drive. Anyone know why?
No,Do you mean the “bars” that you push forward to go and pull back for reverse?
never heard them called “tow levers”?
Also do you mean the mower will not go into “neutral” when the bars are in the neutral position?
No, those are the motion control levers, I'm talking about two, small rods, located behind the seat in the engine area. They disengage the HST so the mower can be safely towed. Both of them are moving when I pull them, but only the left one works.Do you mean the “bars” that you push forward to go and pull back for reverse?
I don't see a cotter pin on either of these.Using the bypass rods are explained on page 42 of the operators manual.
Make sure the cotter pin #240 (and all other parts) are connected properly.
The diagrams I posted are from Kubota Illustrated Parts (K-Pad) for the Z421KW.I don't see a cotter pin on either of these.
BTW, thank you for setting us no manual, heathens on the right path!Using the bypass rods are explained on page 42 of the operators manual.
Your welcome!BTW, thank you for setting us no manual, heathens on the right path!![]()
i see the cotter pin now that I pulled the tire, the linkage is intact, it turns a square shaft on top of the HST. Looks like the problem is inside the HST.The diagrams I posted are from Kubota Illustrated Parts (K-Pad) for the Z421KW.
Take a picture of what you do have and post if you can so we can see what's what.
