Three Point hitch acting up
tealetm
B7200 and B2601
Apr 20, 2015
51
Upstate, NY
B2601 with 300hrs.
the three point hitch just started acting up the other day and I’m stumped.
I just changed all fluids and filters to see if that would help but it hasn’t changed anything. All other hydraulics work just fine.
hitch arms don’t always raise up when the lever is raised- most of the time they do but sometimes they don’t until I lower the lever then lift it again. When they do lift they sometimes only raise midway then stop, other times they raise all the way. Any upward movement is slow however. Downward movement is fine and there isn’t any leak down when weight is added to the arms. The knob under the seat which controls the speed of it going down does close fully and if closed stops the arms from dropping like it should.
again, all the other tractor hydraulics work fine (loader, steering, hst).
im at a loss- any thoughts?
11,231
First thing to check is that the feedback linkage is intact and moves without binding.
3,144
Then make sure the lever you move is attached well to the control valve stub that should be moving to raise and lower the three point hitch.
jimh406
Kubota L2501 with R4 tires
Jan 29, 2021
2,980
2,357
Western MT
Check your drop speed/hydraulic flow valve under the seat. Maybe it's too tight or needs to be adjusted.
tealetm
B7200 and B2601
Apr 20, 2015
51
Upstate, NY
Thanks for the feedback. The drop speed is fine and works as it should and doesn’t change the lift problem when I change it.
The shaft going to the internal valve does turn when I use the lever, but there is play at this point in the linkage- is there supposed to be slip here by design or is a bushing or something missing? IMG_1055.jpeg
11,231
Yes that play is normal.
Does the tractor have a Backhoe, or did it have a BH?
tealetm
B7200 and B2601
Apr 20, 2015
51
Upstate, NY
I think I figured it out- the actual feedback linkage is moving but not turning the shaft going to the valve- the linkage is twisting instead.
not sure how to free the frozen shaft?
3,144
In post #8 lower picture see part #10. It should be mounted onto a round shaft that sticks out of the tractor case. Spray that area where the shaft enters the case with a good penetrating oil like PB Blaster or whatever you like but WD-40 is not the best option. Then try to wiggle the lever part #10 and see if it moves. If not let it set for a few minutes and then spray it again and try to move it. Let it soak overnight if it doesn’t break free and spray it as often as you can within reason.
Keep after it and it should move freely by the feedback rod.
You may need to replace or reinforce whatever is twisting since that may be too weak to function properly.
tealetm
B7200 and B2601
Apr 20, 2015
51
Upstate, NY
Well yes- once again you guys were correct.
The feedback linkage was frozen up. Its a bear to get to and see whats going on but I believe i have it semi-freed up now. The linkage is twisted and seems pretty soft so I ordered a new one.
The trick is going to be figuring out how to swap it out without taking the whole tractor apart.
And then of course I have to figure out how it actually works and where it should be adjusted.
But, I think I'm on the right course finally.
