Belt issue or Tension issue?
The original mower deck belt lasted 9 cutting seasons but was beginning to crack at the end of last year. Put a new one on it at the start of this year and it just seperated last week. Put a new one on it today and I could smell a faint rubber burning smell when I engaged the PTO. This also occurred sporadically with the previous replacement belt. With the plastic covers over the belt removed on both sides it appeared that the belt is loose by the left blade pulley but appears to have good tension on the right blade pulley. The pulleys all seemed secure. The first replacement belt was from Amazon but the new one I just installed is from the V-Belt Guys. Is it a belt issue or a tensioner issue (i.e. the tension spring needs replacing)?
