BX23 hydraulic leak need help
Artractor
L45 TLB
Jul 21, 2015
9
GARFIELD
Hi. Was operating and sprung a leak at the filter. The filter housing appeared cracked so I replaced it, filled the system, ran for a few minutes, then fluid starting spraying at the base of the filter again (at the gasket but kind of hard to tell with it spraying everywhere).
Can anyone point me in the right direction? Pressure relief or some valve stuck in the system? Fluke bad filter? Any ideas?
Bee-Positive
Nov 16, 2022
1,174
1,087
Amsterdam, NY
What were you doing when "operating" just before it sprung a leak?
When you say the filter housing was cracked do you mean the filter was cracked or the housing the filter screws onto was cracked? Did you inspect the old filter that "appeared" to be cracked to be sure it was in fact cracked?
Have to ask - did you make sure you removed the old O-ring with the old filter? Sometimes the old seal can remain on and it gets "double" ringed causing a bad seal. Hence another benefit of inspecting the old filter.
5,531
@Bee-Positive has some good suggestions, double check everything.
I have had oil filter gaskets "stick on" like he mentioned, But if it's actually rupturing the filter, you have some "issues" beyond my understanding.
EDIT: I made a "guard" to protect my hydraulic filters, cause it looked way too easy for a stick to knock them off/poke them....I actually had a stick knock off my fuel filter when it was new, hence my making guards. (y)
Artractor
L45 TLB
Jul 21, 2015
9
GARFIELD
I was operating with loader moving some dirt.
The filter was ruptured where the cylinder housing is crimped onto the base. I thought maybe I had run over something that hit it and did not put a ton of time into diagnostics at that moment.
The mounting face was clear and flat, no old gasket. The old filter had its o ring still on it.
I had also cleaned the screen tube when I filled it back up, figured it was basically a hydro oil change at that point.
Bee-Positive
Nov 16, 2022
1,174
1,087
Amsterdam, NY
There's a Relief Valve Spring where the filter connects - get the WSM and check it.
Edited to remove the wrong information - sorry about that.
Bee-Positive
Nov 16, 2022
1,174
1,087
Amsterdam, NY
Read this post about a similar issue with an L3901. Although a different tractor model whitetiger lists a good methodology on trouble shooting in post #6.
3,776
2,183
You have a relief valve just below the filter; unscrew the plug, and there will be a spring and spool. See that they are clean/clear.
Artractor
L45 TLB
Jul 21, 2015
9
GARFIELD
Update on this (spoiler alert, isn't fixed yet).
I found the relief valve, it's a 17mm plug with a spring and a poppet. I took all that out, inspected (seemed fine), cleaned, and then also cleaned where the poppet seats by taking another drain plug off just below the filter and flushing thru there to try to get any metal shavings, debris, etc.
Put a new filter on. Put some hydraulic oil in it. Fired it up. After a few seconds, filter ruptures again!
I'm going to go read that linked thread, but if anyone has any ideas, I sure appreciate it.
Artractor
L45 TLB
Jul 21, 2015
9
GARFIELD
Another update...read thru that other post and then the WSM. Nothing new except maybe take apart the hydraulic fittings to look for a physical blockage.
Artractor
L45 TLB
Jul 21, 2015
9
GARFIELD
Have you opened the original filter and inspected the filter media for debris?
No I haven't. I suppose I figured that trying 2 more filters would rule debris out, but after seeing that other post, maybe it would indicate debris somewhere in the system (since that other post somehow had a plastic plug in the fitting.
  • Sad
