Oil leak from LA403 control valve.
Jsmart
2005, B3030, LA403, RC72-B30, Box blade, tiller, Bush Hog, Harrow.
Sep 19, 2026
I have a 2006 B3030 with a LA403 . It’s leaking oil from the control valve . Any chance others have experienced this problem?
Grandad4
Apr 5, 2016
445
195
Greensboro, NC
Could you be a little more specific about WHERE the leak is? There are multiple lines, connectors, fittings all over that thing. Is it one of those or what? Take and share a picture of it you can.
Jsmart
Sep 19, 2026
You may need to replace one or .ore seals on the spools. A little fuller description of exactly where its leaking would be helpful.
Dab
Thanks, I’ll have to try to identify exactly where it is leaking from. All I know right now it’s dripping from the low point of the valve block assembly.
Jsmart
Sep 19, 2026
I cleaned it up yesterday and ran for a hour using the loader. I will check it out today
Jsmart
Sep 19, 2026
Looks like it’s leaking from the blue and white quick connect fittings. Are these fittings known to leak?
Jsmart
Sep 19, 2026
Correction, it’s leaking from the blue and yellow quick connect fittings.
7,323
Its not uncommon for quick couplers to develop leaks. Is the leak coming from the tips or at the base? Do they leak when not connected?
Jsmart
Sep 19, 2026
Near as I can tell it’s leaking from the female side.
Jsmart
Sep 19, 2026
When disconnect I do get a few drips but nothing more.
3,134
The orings in the female body should be able to be replaced. You can also try to clean them and see if they stop leaking.
