Hydraulic mods
Paul Allwood
Kubota B7200HSTD, RC60-72H MMM, homemade FEL, forks & ballast box, rotary hoe
Jul 8, 2025
770
1,397
When I made the loader for my B7200 8 based the hydraulic connections on the B1630 loader that was one of the models spec'd for this tractor. This has QC fittings in the supply line to the valve, the PB line from the valve and the tank return line from the valve. This means that if I remove the loader the valve goes with it.
I've watched videos of newer models where if the loader is removed the valve stays on the tractor, leaving it available to operate other things. These use either multiple QC's or 4 (?) QC's in a single connector block.
Would I be right in thinking that these QC's are in the lines from the valve work ports ?
If that's right, I'm thinking of doing something similar to mine by fitting QC's into the work ports on my valve. I'll also need to cut the valve bracket off its current spot and re-weld it into the upright that stays on the tractor.
I'm thinking I may add a cylinder to the front mower mount to provide lift, and also a cylinder for side shift. Also thinking that it might be better to remove the loader for mowing.
Thoughts ?
Am I better fitting the QC's directly to the valve or running hoses from the valve to the QC's that I would mount somewhere else ?
Are there better or worse QC types to use ?
All advice appreciated.
Here's the hoses currently connected to the work ports.
11,184
QC on the valve is quick and simple.
My Woods loader on my L is done that way.
The towers and valve stay with the tractor on loader removal.
It also eliminates extra parts that would be needed to mount it remotely.
Paul Allwood
Jul 8, 2025
770
1,397
Is there a standard, or better/worse way of positioning the QC's ?
For example, male on the A ports, female on the B ports or vice versa ? Those would seem to make it easier to connect things the right way around.
Female on all the valve ports colour coded ? This would have the cavity in the QC fittings facing up ready to catch dirt.
Male on all the valve ports all colour coded ? This would have the male QC fittings facing up, less likely to catch dirt.
Whichever way I go I'll need caps or plugs to seal off and disconnected QC's.
7,321
Check the work port spacing carefully. The spacing on many small valves is too close together to accomodate QC's.
11,184
Mine has the QC female on the valve side facing downhill.
The have caps on both ends.
Color coded lines and fittings.
The males on the loader end makes sense to me, as the loader lines almost always end up facing all different directions and sometime end up on the ground.
Paul Allwood
Jul 8, 2025
770
1,397
Yep, hadn't thought of that. Thanks.
