M7040 head replacement
brendan1457654
M7040
Sep 17, 2026
NSW
Hi All
Im looking at replacing a leaking head. I have a quote fromYEM parts for a complete head with valves. What i cant find is the torque and sequence for the head bolts and rocker rail. Please help.
Also has anyone i stalled a head from YEM parts china. If so how did it perform?
11,202
Hi All
Leaking head? :unsure:
Elaborate please.
brendan1457654
M7040
Sep 17, 2026
NSW
Elaborate please.
The tractor had a severe overheating event. Radiator had a hole in it. Replaced the radiator and filled with new coolant. After starting and running for about 30sec coolant is pushed out the overflow tank. After turning if the engine and opening the radiator cap pressurused fluid escapes followed by gas.
On the same subject does anyone have the part number for the complete gasket kit. Im looking for the the 1 notch kit at this stage. Hopefully its just the gasket that has failed but will know more after I get the head pressure tested and inspected the engine shop.
11,202
You don't need to have a shop inspect it and pressure test it.
Just look at it, it will be quite evident if it's cracked.
Need the serial number of the tractor and the engine to see if I can get any info on the head gasket as there are quite a few options.
brendan1457654
M7040
Sep 17, 2026
NSW
brendan1457654
M7040
Sep 17, 2026
NSW
I cant see a crack of sorts but still concerned it may be warpped. I have not git the equipment to do a propper check of any deflection so I think its best to get it checked at the shop.
