R ranacom New member Equipment L2201 Jun 8, 2026 5 1 3 SRI LANKA Wednesday at 12:07 PM #1 KUBOTA L2201, engine model DH 1101, RPM 3000. I insert SAE 15W-40 type for GEAR BOX, is it ok, I need to know which type excellent for gear box
Caden Active member Equipment 1979 B7100 Apr 16, 2026 293 161 43 Virginia Wednesday at 1:48 PM #2 ranacom said: SAE 15W-40 type for GEAR BOX Click to expand... Do not run engine oil in your transmission... I think this thread may help you Reactions: 1 user
mikester Well-known member Equipment M59 TLB Oct 21, 2017 4,143 2,833 113 Canada www.divergentstuff.ca Thursday at 3:03 AM #3 Try something like 80W90 gear oil
B Bee-Positive Well-known member Equipment BX1880, Cab, FEL, Tooth Bar, MMM, QH, Ballast Box Nov 16, 2022 1,135 1,058 113 Amsterdam, NY Thursday at 6:41 AM #4 ranacom said: KUBOTA L2201, engine model DH 1101, RPM 3000. I insert SAE 15W-40 type for GEAR BOX, is it ok, I need to know which type excellent for gear box Click to expand... Don't confuse "Gear Box" for "Geared Transmission". As Caden stated DO NOT put SAE 15W-40 in the transmission! Your geared transmission must use any universal UDT transmission oil. The engine can use SAE 15W-40 designated for diesel engines. Don't use the same stuff you put in your non-diesel cars. The steering box, front axle can use 80W90 gear oil. Reactions: 1 users
R ranacom New member Equipment L2201 Jun 8, 2026 5 1 3 SRI LANKA Saturday at 8:14 PM #5 Caden said: Do not run engine oil in your transmission... I think this thread may help you Click to expand... Thank you
