Issues with loader dump after overpressure/blown line L5460
CdnSldr.ret
25
NW Ontario, Canada
Yes - that thought did cross my mind but I cant formulate a failure.
Thats the load check valve that holds the load side pressure untill pump side pressure rises to match. Its easy to examine.
This might be one for the dealer to figure out. Well worth the $250 insurance deductible.
Either way, thanks for your effort on this.
7,345
I was able to find the hydraulic schematics in the service manual. I’m convinced the issue is with the load check valve not fully operating.
Yes, I looked at that yesterday. As I suggested remove and inspect it. Its just a one way poppet.
Unfortunately, if its damaged replacements are NLA. I know in the past components (poppet??) from other valves have been successfully swapped in.
7,345
I know this seems like a possibility but its a reverse flow check on the pressure out port. Your tests show that port is working fine. I can not visualize how the load check could block the return port.
CdnSldr.ret
25
NW Ontario, Canada
It has been a few years since I’ve had to read hydraulic schematics, but the load check operates in the return circuit does it not? Supply pressure actuates the load check to allow return flow.
7,345
No. The load check operates on the pressure out port.
Example:
When the loader is in a raised position pressure in the lift work circuit is held by the glands on the spool. They block both ports.
If the spool is shifted to further extend the cylinder the glands are repositioned to divert pump flow to the output port and simultaneosly open the return side.
The load check valve keeps the pressure port shut until pump side pressure builds and exceeds the existing pressure if any in the work circuit. At that point pump pressure forces the check valve open and flow goes to the cylinder. This prevents any held load from sagging as the port transitions to open and pressure builds.
