Where am I leaking from?
MOlivin
L6060
May 15, 2023
78
17
MO
Hi All,
Per the photos below, I go to the L6060 the other day and see oil leaking from the front left wheel.
Removed the wheel today to see where it was coming from, and it must have been leaking for a bit as theres oil everywhere and I can't see exactly where it's coming out of.
Anyone know exactly where the oil is coming from? Is this just a gasket that's leaking I can fix or what?
Thanks all!
hagrid
K1600GTL, ZX-14R
Jun 11, 2018
1,217
1,835
Pittsburgh
Hard to determine the source.
Purchase one can of Brākleen and apply liberally to the soiled surface. With any luck it won't take long to identify the culprit.
11,197
Above is the best answer
If I'm going to guess, it's the axle seal.
You'll need to check the bearings, as a bad bearing is one common reason for the seal to leak.
MOlivin
L6060
May 15, 2023
78
17
MO
will do, thanks guys!
Luckily i already have some break cleaner... unluckily it's starting to rain.
I'll report back with my findings.
I'm guessing they do not make a full wheel bearing assembly like a car? so I don't need to rip it apart and press in each induvial piece
11,197
No press required they are all slip fit parts.
It's a fairly simple job to do.
netspyder
L3010HST
Jun 9, 2025
40
76
Missouri
check the hoses above ... like... if the tractor didn't move how did the oil get to the top of the wheel hub?
JimDeL
BX2380; 54" MMM; FEL w Pirahna bar; Ballast Box; BXpanded skid plate.
Aug 31, 2022
475
551
NE Ohio
That happened to me. A leaky fitting on the FEL dripped onto the wheel hub. I caught it before I started tearing the hub apart, though.
MOlivin
L6060
May 15, 2023
78
17
MO
Cleaned it up this morning, sat for a while and nothing... lifted the right wheel to move the oil to the left side, about an hour later it started flowing.
What all parts will I need to replace, just #80.... probably #140 just to be safe?
Thanks again all!
11,197
Thanks again all!
Lift that axle off the ground, with a tire on it wiggle the tire top to bottom to check the bearings.
Any movement or noise buy 2 new bearings also.
And yes you need 80 and 140 at minimum.
MOlivin
L6060
May 15, 2023
78
17
MO
There is no wobble or noise, it just seems to be the leak. But I only want to do this once...
What all parts would be best to get and just replace? All 7 of these?
30
20
50
60
70
80
140
Tractor just hit 1200 hours, I assumed these would have a much much longer lifespan then this.
Thanks again!
MOlivin
L6060
May 15, 2023
78
17
MO
30
20
50
60
70
80
140
Thanks again!
Just checked it again moving the top of the tire back and forth, yeah theres a lot of play, the right side has zero play.
So basically I DO need all those parts listed then?
Workerbee
Zd21
Mar 1, 2020
382
266
MN
If you can take it apart before you order parts then you would know exactly what you need. If you want to minimize downtime, order the works.
11,197
30 and 70 have mutiple widths and you will be able to use the ones you have, they don't wear.
Also 50 should not wear, they are keepers if they failed the axle would just fall off.
You only need 20, 60, 80, 140
08101-06208
TD170-13150
31393-43530
34550-13152
MOlivin
L6060
May 15, 2023
78
17
MO
08101-06208
TD170-13150
31393-43530
34550-13152
Getting them on order today. Thanks again for the help!
