B1402 Workshop manuals
Grey Import
Kubota B1402DT
Sep 10, 2026
Devon, UK
Hi - would anyone have the workshop manual for the B-series tractors - mine is a grey import a 1402DT. Built around 1985.
11,184
As you probably already know there is no B1402 manual.
What part of the tractor are you needing help with?
As that might help determine which manual will work best.
If it engine, get the model number of the engine off of it.
It's stamped on a flat just to the side of the injection pump.
Grey Import
Kubota B1402DT
Sep 10, 2026
Devon, UK
Grey Import
Kubota B1402DT
Sep 10, 2026
Devon, UK
Thanks for the info Wolfman, I didn't know about that. I want to repair the hand operated throttle (its stopped holding position and instead drops the revs) and also the Hours clock has stopped working - i was never sure it ever worked well or calibrated since the tractor was rebuilt a year or so ago.
11,184
On the throttle issue there will be a set of double nuts and washers at the pivot point, those hold tension on the lever.
You unlock the two nuts then adjust the inside nut to put tension on the washers and lever, then lock the outside nut back down to the inside.
If the hour clock is electric then there should be a fuse under the dash that feeds it power anytime the key is on.
Grey Import
Kubota B1402DT
Sep 10, 2026
Devon, UK
Much appreciated again and thanks Wolfman,
Best, Grey Import
