HST neutral spring hitting Drive shaft
Jamesm2888
KUBOTA B6200 HST 4WD 1983
Sep 10, 2026
Carrickfergus, Northern Ireland
Hi 83 B6200, HST 4wd, had to fit a new kubota spec Neutral HST spring, after old one disappeared into ether, its now hitting the driveshaft coupling as it rotates, ive fitted and refitted it, eye of spring in and out, no change, what can I do, space is insanely tight between the coupling and casing of box, one side of coupling hits spring on rotation when moving
SDT
Apr 15, 2018
3,705
1,422
Not uncommon. My B1750 had the same problem.
Eventually, I was able to get it to clear but only slightly.
IIRC, the replacement service spring has a small piece of rubber hose inside to damp out vibrations, lessening the problem.
Might want to inspect/change the pedal dampener as well.
11,249
If any of these are are worn too much or bent it will do that.
Jamesm2888
Sep 10, 2026
If any of these are are worn too much or bent it will do that. View attachment 179199
yes thanks for that, ive removed that part today, lots of play, ordered new part 100 110 and.120 today £85 at local kubota, hopefully sort it, ws looking at part 150 to 170 cannot see anywhere in the vicinity that the roller comes into contact with, what does it connct to assume it should be on the casing of chassis, could it have been discarded at some point?
11,249
150 contacts this part
