Air in oil. What is normal?
hagrid
K1600GTL, ZX-14R
Jun 11, 2018
1,209
1,824
Pittsburgh
I think that is water; not air.
JonM
Nov 29, 2024
284
677
wisconsin
water would be in the bottom. those are air bubbles. check your fluid level. aeration from what i understand is caused by low oil level
William1
BX25D, JD X754 AWS Mower
Jul 28, 2015
1,466
657
Richmond, Virginia
Excessive air in oil comes from two methods. One, too low an oil level, the oil scavenge sucks in air and churns. The other, too much oil and the crank spinning froths it up.
Lrex
L2502
Jul 16, 2026
Nevada County
Ok, the oil level is normal. Can you tell me what scavenging is?
3,117
T
Think about a kid trying to get 110% of a drink out of a cup through a straw. Slurping is another way to think of it.
3,117
Yes.
But you may want to look at all the rubber hoses and the connection points on the suction side of the pump. There may be some issues that allow air to be sucked into the oil. The issues are loose connections, cracked hoses or leaky joints.
But honestly you have shown a cup of oil with entrained air and asked if that is normal. But you don’t say much else. Like how you got the oil out of the tractor, why you are concerned about it, why you started to even look at the oil.
I don’t have a hydrostatic drive tractor so can’t say if that is normal or not. I can say that oil returning to a transmission case may have some entrained air in it but if there is foaming that is not normal. The air should get out of the oil quickly and not foam. There are additives in the oil to help that happen. Are you using the correct type of oil? Is the tractor trying to creep foreword or backwards at all? Is there any squealing noises? How long have you noticed this happening or has it suddenly started? Has anything happened to the tractor and then this started?
7,314
Anytime you pump oil through a hydraulic system it creates aeration. Lots of factors affect the amount of aeration including oil temperature, sump size relative to flow rate, orifice sizes, etc. Some aeration is normal and I think you are looking for a problem where none exists.
4,222
I respect Dans’ expertise with hydraulic systems but I strongly disagree that “Anytime you pump oil through a hydraulic system it creates aeration”.
In a healthy system NO aeration should occur. Aeration is harmful and is the result of either low supply in the sump (where the pump sucks air up with the oil)…Or, a leak in the suction-side of the system. Look for a leak or a break between the oil in the sump and the pump.…or a leak or crack at/in the pump itself.
(Very rarely oil being injected into an existing sump of oil can inject air into the system, …but that is not something to be found in a closed system.)
7,314
Nonsense. Do a little research. Or a sumple experiment like filling a bucket with a garden hose.
Gas entrainment is an unavoidable phenomenon in any hydraulic system where fluid is being pumped at high pressure and flow rates. Limiting it is a primary concern when designing any system.
In addition to ordinary turbulence the cavitation mentioned below occurs at many places in a high pressure high flow system, not just the pump. Cavitation and resultant aeration occurs in any high shear region - e.g flow restrictions like the glands on valve spools.
All of that adds up to bubbles in the sump where the bubbles are given time to dissipate.
Causes of Air Entrainment
  • Suction Leaks: Loose hose clamps, microscopic cracks, or worn pump shaft seals allow the intake side to pull air directly into the fluid. [1, 2]
  • Reservoir Issues: Low oil levels create vortices that suck surface air down, while undersized tanks or missing internal baffles give bubbles too little time to escape. [1, 2]
  • Turbulent Returns: High-velocity oil or return lines dumping fluid above the tank level cause splashing and constant aeration. [1, 2]
  • Pressure Drops: Sudden pressure releases or restrictions at the pump inlet cause dissolved air to turn into gaseous bubbles. [1, 2]
4,222
edited
It is Not “nonsense”. Sometimes even AI can lead one to proper understanding. Google “is it normal for a hydraulic system to aereate?” …and see what results. Without relying upon the AI explanation itself….Take a look at some of the references provided there…including the educational ones from Real, Actual Hydraulic manufacturers.
11,150
Looks normal to me too.
Depending on how you got the sample that might explain some of it too.
5,476
Maybe I missed it, but is there a problem the OP is trying to solve? (i.e. FEL not working, strange noise, tractor not moving?????)
I mean, no disrespect intended, but how/why would someone take a sample of their hydraulic fluid?....Just for "kicks and giggles"?
Just curious. 🤔
Lrex
L2502
Jul 16, 2026
Nevada County
Thank to all who responded. I purposefully left out whether there were any symptoms on the Tractor because I want to know in general is that amount of air in the hydraulic oil OK or not? or maybe it is sometimes. I am beginning to think it is normal for the L2502HST. I checked the hydraulic oil in 3 different L2502s and the oil looks the same.
Implement hydraulic pump makes a rattle/wine only at idle AND after having done work for about 30 minutes.
The oil level is normal.
It did this before and after the first service. (Filters changed)
Progressively gotten worse.
Unless the dealer put the wrong oil in it should be udt2.
All hydraulics function completely normal.
Oil sample was taken thought the dip stick hole.
See both videos I’ll upload to see the difference between cold idling and hot idling.
7,314
That sounds like the relief valve unloading.
If that happpens too frequently or is constant that can create a lot of aeration. Constant unloading is not normal and indicates a problem in the hydraulic circuit.
Does the loader lift and lower normally?
