Pto clutch not engaging
7,292
Thank you sir! This gives me a direction to look into !
You are quite welcome. If the previous owner never used the PTO its quite possible the PTO clutch plate is stuck but I would check and verify adjustment before fighting that battle.
3,934
2,435
I have not adjusted the pedal yet but the pto lever works as advertised when. Tractor is off . Am I to understand the clutch depresses further for the pto than regular transmission shifting? I’m hoping this isn’t a stupid question!
YES, and it may require significant effort, you're disengaging 2 clutches.
You really should review the Operator Manual. Among other things, it gives the instruction to pin the clutch disengaged for extended down time. There's also a WorkShop Manual WSM at the link I gave earlier. They're free to download.
Hubby17
3901 l
Aug 21, 2026
11
S.Carolina
Excellent! Thank you sir . I greatly appreciate the time and information!
11,121
Dan you are the man. Had 3 inches of play in clutch peddle, adjusted as you said , she’s operating as advertised. I appreciate your time. Next time I will try to be more specific with my issue!
@PoTreeBoy is not Dan
Dan is @TheOldHokie
3,934
2,435
As long as it's working. Sometimes I don't know who I am. Oh BTW, your problem was it wasn't DISengaging.
4,214
Huh..?
(I don’t worry about extra-terrestrial life in the universe .…. I’m concerned we might be out here All Alone - attributed to Carl Sagan)
