PTO pump for 7100 FEL
lilpep
B7100D
Aug 21, 2026
Tx
Hello forum just wanted to start this thread because i have an after market FEL for my b7100. Ive do e research and found that 6.5 to 7.5 GPM is good for FEL. Since the onboard pump flows less than that it would be slow operation of the FEL.
My FEL has a sump in the pilar/column. So i dont need it to flow back to the tractor. And the extra flow might allow for other controls or functions in the future.
My question is has any one added a PTO pump to the B7100D . What pump would you recommend?
11,311
A regular 540RPM pto pump driven from the rear will not work for several reasons.
Lack of available HP to run the pump is #1
Not having a Live PTO is #2
The original option was to use a front PTO (crank driven) pto pump.
But the parts for that would all have to be fabricated as stock parts have long been obsolete.
3,165
You may be able to add on a belt driven pump. But there are no kits for that, you have to fabricate one. @TheOldHokie may still be able to help with information on how to proceed with that.
11,311
You can run the loader off of the onboard pump, yes it's just slower.
But it's quick and easy to set up.
