rocker shaft assembly for a L185DT?
rhouseksa
L 185DT
Jun 10, 2026
Eagle Rock, MO
I have a L185DT that I bought with no lift on the 3 point hitch. I have checked &/or repaired everything the Kubota manual recommends and I am now down to the Rocker Shaft Assembly. Is anyone aware of a complete rocker shaft assembly overhaul kit with bushings, springs and O rings that is available for the L series? Have any of you torn into one of these thing that can give me advice on what to expect in the overhaul. This machine has about 2600 hours on it but looks like it was used very hard, Thanks in advance, Jeff
3,689
2,106
What is the hydraulic oil pressure to the 3-point control valve?
rhouseksa
L 185DT
Jun 10, 2026
Eagle Rock, MO
How and where do I connect a gauge to check this? I now have a 3000 psi gauge I can plug into the output line the previous owner used for a log splitter but it shows no pressure when connected even though It does flow a lot of fluid. And what is under that plate if I remove it and replace it with a solid plate?
11,078
A picture is worth a thousand words.
You need to loop those two lines together, then your three point will work.
3,093
There will be two holes under the plate (that match the location of the hoses).
A solid plate will block all flow and (probably) dead head the pump. The two hoses look like the are actually acting as a solid plate since they are not connected together. Hopefully your pump has not been damaged by running in that condition.
The original cover was drilled with an internal loop. The cover you have was a replacement that allows for external hydraulic flow to operate implements.
You can see this in detail in post #1 of this thread
Same concept on a different model tractor.
You should do as instructed by NIW above and connect the hoses together and see what happens.
3,689
2,106
After seeing the last picture, the pressure at the control valve is going to be "0 PSI".
Didn't even need a pressure gauge to know that. ;)
11,078
Running it like it is destroys either the relief valve or the pump, either can happen. ;)
