Enclosed cargo trailer roof leak repair
2manybikes
19 L3560 HST with cab.
Aug 2, 2021
SW Va.
I've got a couple small roof leaks on one of my cargo trailers. Once I have it clean, I'm wondering if I should just recoat the entire roof? Can anyone recommend a flexible sealer they have used on a cargo trailer roof?
jimh406
Kubota L2501 with R4 tires
Jan 29, 2021
2,963
2,349
Western MT
I'd just clean the immediate area and use Eternabond tape. They make it in several colors and widths.
KKBL
Jan 5, 2022
135
146
Girard, PA
The Eternabond type tape could work well on seams and perhaps small holes. It is not easy to apply smoothly by yourself, so having an extra set of hands to help is advised.
#40Fan
637
469
Poke around on RV forums. There was something that I used years ago on my FIL's camper that is still working today. It was an elastic type paint.
OrangeColoredTractor
2017 L2501 4WD HST
May 10, 2017
75
22
Washington
Get Dicor self leveling sealer on all seams and joints. Dont feater it. Let it do its own thing. Order from amazon. I used white.
Then when it was all dried i did the white rubberized roof coating. 3 coats. Roof metal in sunlight to touch from inside is so much cooler. No sweat on roof and white makes it so much cooler on the inside.
I just went through this same deal
Poohbear
Jul 6, 2018
567
206
Gilmer,Tx,United States
A lot of RVers use products by " Henrys " and rolls/brushed on.
If you are planning on keeping this trailer a long time look at getting RV Armor spray as you are done with any roof leaks & I have had this done to a rv. Its pricey but I had a pretty good insurance check in hand when I had it done.
Kurtee
BX2660, BX2680 cab, JD 2032R, Honda 5518, JD X590, JD X739
Oct 3, 2013
336
148
Nicollet, mn
Through the roof by Sashco. We used it on semi trailer roofs and others. available in tubes or larger containers to brush on. I would just put it on the existing holes. It has worked for me. When they say crystal clear that is what it is. Sashco website can direct to a retailer.
Through The Roof! | Sashco
