New dude looking for buying advice
Trackselk
ID
Howdy,
I'm looking for a small farm tractor that's going to be used for some dirt moving, and grading for 2 years or so, and then mostly snow removal with a blade. Not interested in expensive snow blowers as I have a walk behind I'll use when I'm not in a hurry.
I think I've decided on a used $7-12k no DEF or EGR kubota, but I want to make sure I get enough tractor.
It'll be used in Donnelly, Idaho where the snow is usually blown down to about 2 feet of dry snow. I'd like to be able to get through a few feet of wet snow on a "snowmageddon" winter, but I'm OK with using a bucket to peck away at it on those rare winters, versus getting a bigger machine that's much harder to fix and more expensive.
I'm a diesel/gas mechanic/electronics tech and can fix most anything, but I'll have to learn how to build soft hydraulic lines.
I have 150-300 yards of pit run to move, and I want to be able to rip up the incredibly tough sod from the local pasture grass, and i want it to be able to slowly take the ground level down about 6 inches, but I can water it first so the ground is not like stone. The ground is extremely soft here in the spring, but the roots of this grass are extremely tough (for grass) .
Later on it'll just be snow removal and gravel driveway grading. I'm not worried about the gravel being swept to the sides and I'll fix that by hand and tractor in the spring. Just don't want to deal with wearing out an expensive pto driven snowblower when I have plenty of room to push snow. Not to mention braking shear pins and getting gravel stuck in the auger...
I found a L2850d 4500lb kubota with loader and box blade for $10k, but it'll cost me 2 days to retrieve and probably $500 in diesel on the old cummins. It's has just over 2k hours and alleged good maintenance. Tough to want to drive that far to look at it, so I'll probably pass. But, I'm wondering if the price is decent if it's a solid machine? And, is it enough machine.
Lastly, I think I want a front push blade, but I'd like to hear what you experienced folks have to say.
Edit: and could I get away with less tractor, like one of the units that are around 2-3000 lbs with a loader?
I greatly appreciate any advice!
4,203
WELCOME.
Whatever you decide….made certain it’s ORANGE.
Avoid Green, Red, and Blue tractors. (and, with prejudice, cast askance at KIOTI)
Bee-Positive
Nov 16, 2022
1,074
998
Amsterdam, NY
Look for a tractor with a quick attach bucket which that older L2850 does not have.
Will make it very easy to change implements - from bucket to blade, or any other SSQA attachment.
Trackselk
ID
Thanks for the advice! Makes me wonder if they have any good front blades that attach to the bucket. I plan to buy or have made a set of hay spears for the large bales. Maybe I need a bigger tractor? I'll have to look up the weight of the large bales of alfalfa grass mix
Bee-Positive
Nov 16, 2022
1,074
998
Amsterdam, NY
You'd be lucky to lift 700 lbs. with an L2850. Lifting bales make sure you get something for rear ballast, weight box, filled tires, heavy 3 pt. attachment, etc. Go low and slow while doing it.
There are many "store bought" blades available that attach to the bucket.
I cobbled one up for my BX using an old Craftsman blade I had laying around. It stuck out quite a ways and adding the plow weight to the bucket weight it bounced like hell. Used it for two seasons until I got a blank SSQA plate and fabbed a blade to it. Is much better all around without the weight of the bucket. It's pretty crud but it works for me. I can quickly switch from plow to bucket when I want to move snow banks.
11,067
Your in a Tough area of Idaho to get anything local.
It's hard enough for me and I've got Spokane hour and half away.
You'll need and Large L or a MX or M to deal with large bales.
Anything else is simply worthless on Large bales.
Your not going to get a good condition L, MX, Or M for the amount of money you want to spend.
Your looking at $15K + minimum for anything worth anything.
You want a loader that can do SSQA attachments as a blade for any older tractor is hard to find.
FYI: Large square bale of mix weight 1200lbs to 2000lbs.
Trackselk
ID
Great info, thanks to all of you! Especially the 3pt hay spear part, that might just make a little tractor move big bales. I only need to move them a short distance on flat ground, and I could probably use a chain hoist to stack them. I already love this place!
4,203
I ran into this issue when I bought my M4700DT….it had “pin on” FEL…and I was advised to alter it to a SSQA style. THAT would cost Real Money …Plus my tractor already had a pin on bucket that ..if I converted to SSQA would no longer fit… :sneaky:
So INSTEAD…I did something which has worked out Very Nicely for me: I asked Dan Heibert to make pin-on Quick-Attach Bracket-Mounts for me.
Here’s a couple links where I discussed my experience …and subsequent satisfaction.. Included is a link to YT video that shows how simple this device is. I leave my top pins IN permanently…and simply drive up to the bucket (or forks, or whatever pin on implement desired) … lift the implement with the FEL and stick the lower pins into the bracket… and Drive away with the bucket/forks/whatever.
No loss of weight capacity or expense of SSQA alteration…and can continue to use existing implements. (and if desired, Hayspear dot com will make a pin-on-to-SSQA adaptor …and you can use any SSQA implement also, if in the future you acquire SSQA implements.) Hope this helps.
Here’s the YT video:
Here’s where I told about my experiences with Dan Heiberts’ bracket:
Bee-Positive
Nov 16, 2022
1,074
998
Amsterdam, NY
For a VERY ROUGH estimate of how much a loader will lift multiply the model by 1.6. For example for an LA525 loader: 525 x 1.6 = 840 then subtract the bucket (or anything attached) weight. Again, very rough estimate, but useful when you're standing out in the lot tire kicking or shopping on line without the specs in front of you.
Lots of ways to skin the cat for lifting bales. I wouldn't go with the clamp-on type for the large bales, could be rough on the bucket.
7,004
Its really gonna depend on what size large bales you are talking about. I move 3x3x6 (#600-800) without any issue with a pretty small tractor. The larger 3x4x7's (closer to #1000) are getting close to max for LA 534 on my B-2650. I can still stack them 2 high with that little machine (using a set of heavy forks).
They "feel" lighter with a bale spear. As I said, my forks are pretty heavy.
Trackselk
ID
Thanks for the pics and ideas! I've never bought the big bales, but I plan to to save money. Not sure what's available around here, but I've seen round and rectangular bales. I'll get some weights to help guide my decision.
The pop ups on this site are making it really hard to respond with my slow phone. I've got to speed this thing up to hang here!
Bee-Positive
Nov 16, 2022
1,074
998
Amsterdam, NY
I'm too old to be typing on my phone, my 4 year old grandson can do better than I can. :rolleyes:
I use a laptop with DuckDuckGo = zero pop-ups.
3,092
Three things will help with the ads
1) Use a different browser like DuckDuckGo or something similar.
2) Use ad blocking software
3) By far the best is to buy a lifetime membership but probably the most expensive option also.
5,365
+1…………..I did #1 and that took care of it for me.
Shawn T. W
Dec 9, 2024
803
1,441
SW Missouri Ozarks
You're getting into the elevation of seeing a benefit of a turbo ...
While I'm a huge fan of the "little micro overgrown lawnmower toy tractors" as some people call my BX sized Sub-Compact Utility Tractor (SCUT) Reading the first post sounds like a MX or even a M sized tractor ... Yes, I've moved and spread just under a million pounds of rock and gravel with my Little Baby Fergie, but it takes a lot of time, one of the disadvantages of a lightweight tractor like mine which weighs 3300 Pounds, is TRACTION!
So I got an older pre-emissions Grand L (bigger than a standard L, similar size to a MX) last summer for bigger tires for more comfortable ride on rough ground ... Without a loader and nearly 4000 hours , for $16K ...
Got it cleaned up ... $20K "big lawnmower"!
Mines about the minimum size I'd recommend ... But for your use you also need a loader ... The model number of the loader is what it will lift "at the pins" ... In Kilograms, multiple by 2.2 to get pounds ... The "pins" are shown below ...
Unless your young and tough ... A cab will make your winter tractor experience much more pleasant.
7,004
View attachment 178076 View attachment 178078 View attachment 178079
Curious as to why you used 1.6X? Are you simply subtracting for the weight of the loader attachment?
Kubota loader model number indicates lift capacity to full height at pins in KG's (2.2 lbs)
Bee-Positive
Nov 16, 2022
1,074
998
Amsterdam, NY
You are correct 2.2 is typical at the pins. I was factoring in the capacity 500mm forward from the pins which is more realistic of how I use the loader.
Trackselk
ID
Thanks! I'm always amazed by how much cabs add to the cost. Yeah, at -35 a cab Would be handy!
