JimDeL
BX2380; 54" MMM; FEL w Pirahna bar; Ballast Box; BXpanded skid plate.
Aug 31, 2022
466
539
NE Ohio
I'm not sure when it came off or where it went. I took a spin in the buggy all around the field but no sign of it.
You'll find it the hard way next time you mow. :rolleyes:
S-G-R
Grand L5460, X1100C RTV
Jun 17, 2020
1,722
4,526
PEI Canada
Made a new pad for the shed. It is just sitting on blocks and sinking. I have patio stones and 6x6's to put down and then it's getting turned 180°.
MotoBBQ
L3902HST w/ LA526 loader; rotary cutter; box blade
Jun 26, 2023
54
323
53
MN
Saturday I put the pallet forks on. The Kubota mostly supervised, while I cut with the chainsaw. Mostly just smaller limbs I had thrown aside, but I wanted to clean up old stuff before cutting new stuff.
Overnight it rained quite a bit, so I used that as my opportunity to mow. Only the second time mowing this season since we've been in a drought.
7,005
Gave the "pasture" next door a quick tune up before the rain.
Reactions: 8 users
3,093
Too many questions about the fencing to not ask so I apologize for that!
In the first picture that looks like “split rail“ posts but the rails look like really good rails or sawn planks. Simple question is what type of fence is that?
In Texas if using sawn boards they are usually face nailed (or screwed) to the post. In split rail the post has holes for the rails to insert into but the rails are pretty rough and look split not sawn at all (except for the tenons).
7,005
Rails are sawn (roughly the same size as 5/4 deck boards (in fact, there are a few of them that were replaced with 5/4). They are not fastened, they simply slide into the post slots with approx 6-8" overlap. Only the corners are nailed/screwed.
S-G-R
Jun 17, 2020
1,722
4,526
PEI Canada
I replaced the male fitting twice on my third function and the latest one was dripping. Decided to try a set of flat face couplers and see if that resolves the issue. I still need to swap them out on my post hole digger and grapple.
Old_Paint
Dec 5, 2020
2,045
2,326
AL
Found a few holes poked in the plastic grille on the LX. Darn the luck. I'm pretty careful using the grapple to make sure all the long stuff that can get me is turned crossways, but I think maybe I did it piling stuff up really high. We cleaned up nearly 3 miles of fence line that hasn't been touched in at least 20 years (including the Callery Pear trees). I think I bumped a couple sticks while trying to put stuff up on top of the pile. Guess I'm buying a new grill (after 5 years of not breaking anything). The replacement is about half the cost of most of the guards I see available for the LX. I like the 511 stuff, but they're pricey. Might have to try my hand at making something with some expanded metal grate. Got a little bit of that scattered about, as well as some light weight box beam.
  • Sad
Gaspasser
L6060, FEL, forks, front snowblower. KX033 mini ex. Dump truck, Husqvarna saws.
Dec 16, 2023
455
728
NH
Continued work on the driveway addition with the foreman "helping." She was kind enough to remind me which section or pile I was working on by lying right in the middle of the active work. When she helps, it only takes 3X longer. 20260818_172554.jpg 20260818_172611.jpg 20260818_145912.jpg
Reactions: 7 users
Old_Paint
Dec 5, 2020
2,045
2,326
AL
Gave SUzie a nose job. (Replaced the plastic grille) After 7 years of being careful and not poking holes, I finally did it last Monday. Not even sure how, but I ordered a new grille from my local dealer yesterday and had it today. Only took about 30 minutes to install, including R&R the badge to the new grille. I guess it’s time to get something more substantial between the grille and pokey things, but seems every solution is nearly twice the price of a replacement grille. Also started the process of getting a quote for an upgrade to the new LX4020SU. I want bigger ponies, but don’t want them to need a bigger stall. I figure if im keeping the chipper and possibly getting a rotary cutter, I can probably put the extra ponies to use. Hopefully I get some good numbers from the dealer. I bought the one I have from them, so maybe. IMG_4316.jpeg IMG_4317.jpeg IMG_4319.jpeg
Old_Paint
Dec 5, 2020
2,045
2,326
AL
Next up, swapping the hammers for Y-blades on the flail……
Gonna recut the fields that I cut earlier and hopefully get more of the weeds under control. They look better already but I cut them with the hammers which mostly beats the grass down because the clippings fill up the hammers and hide the cutting edges. Doesn’t happen with the Y-blades. In exchange for cutting both fields again, I did some bartering for a 5 foot box blade that hasn’t been used in at least 15 years and likely won’t ever be used again unless I get it. All the scarifiers are still on it and it’s the perfect width for SUzie. She’s got 54” hips which makes a 48” blade useless as a screen door on a submarine. I’ll probably sell the BB1248 to someone with a smaller tractor.
7,005
Gave SUzie a nose job. (Replaced the plastic grille) After 7 years of being careful and not poking holes, I finally did it last Monday. Not even sure how, but I ordered a new grille from my local dealer yesterday and had it today. Only took about 30 minutes to install, including R&R the badge to the new grille. I guess it’s time to get something more substantial between the grille and pokey things, but seems every solution is nearly twice the price of a replacement grille. Also started the process of getting a quote for an upgrade to the new LX4020SU. I want bigger ponies, but don’t want them to need a bigger stall. I figure if im keeping the chipper and possibly getting a rotary cutter, I can probably put the extra ponies to use. Hopefully I get some good numbers from the dealer. I bought the one I have from them, so maybe. View attachment 178366 View attachment 178367 View attachment 178368
This outfit has one at about half the cost of the other popular name...not sure what the cost of your replacement grille was.
I got a dif lock pedal mod from them. It was ok.
