Sounds liks a simple open circuit fault in one side of the wiring harness. Consult the wiring diagram and trace power in that side of the circuit with a test lamp.Hi. All of the lights on one side of the rops on my stv36 have stopped working. The other side is fine. What can I test and check please?
Thanks Dan.Sounds liks a simple open circuit fault in one side of the wiring harness. Consult the wiring diagram and trace power in that side of the circuit with a test lamp.
It may seem odd but it matches your lighting problem. You do understand why I recommended testing power with a test lamp?Thanks Dan.
I found a 4 wire cable coming out the bottom of the ROPS. Each wire has an individual connector. After disconnecting them I can see the ground connection and 12v levels are ok on the harness side. But continuity testing all four wires between the connectors and light unit gives open circuit for all four. So looks like the cable inside the ROPS is damaged. Seems odd that all 4 wires are broken though.
Chris
Thanks, yes, although I’ve been using a multimeter instead to check voltages and continuity.It may seem odd but it matches your lighting problem. You do understand why I recommended testing power with a test lamp?
Thank you. Will do. Much appreciated.use a test light for this purpose like Dan stated. A multimeter does not load the circuit and you can see acceptable voltage but not see voltage drop while under a load. If all lamp functions are out the logical place to look is the ground circuit. But make sure you check your bulb(s) as well. It wouldn't be the first time multiple elements were bad at the same time.
Mystery solved. Removed the bracket at the top where the lights connect to the roll bar and found a connector that was disconnected! Thanks again for your help.It may seem odd but it matches your lighting problem. You do understand why I recommended testing power with a test lamp?
