Waste oil burners/heater/stove
5,554
Went to lunch today with a couple of guys from the lodge, you know how that goes. Talk about kids and cars/trucks and what ever solving all the troubles of the world. And the one younger fellow said he was gathering stuff to make a waste oil burner for his garage, and being that he has several large pieces of farm equipment, he does wind up with a bunch of used oil. He said it was an oil drip and he went into detail, and in my own warm and loving fatherly way told him he was outa his freekin mind, and I would bring the hotdogs when it caught fire in the garage. Now it sounded kind of sketchy to me, and I Utubed it and it still looks crazy at best. Has anyone here ever made a crazy thing like that, seems to me to be a bomb just waiting to go off.
3,058
waste oil used all the time to heat with.
Got to have the correct nozzle and great filtering too. Typically the oil needs to be thinned a bit, sometimes not - has to be somewhat clean too.
MapleLeafFarmer
Lots incl. B and L kubotas
Dec 2, 2019
1,168
1,158
E.
not sketchy but highly regulated in a lot of places like here. they make engineered professional units all the way down to homemade drip systems.
takes a lot of oil though.
compared to 1 cord of dry pine, you need about 2 barrels (100+ gallons) of used motor oil to make same amount of btu's !!
John T
2017 BX23S 385XP Miller211 1952 Panhead Orange Ludwig 4 piece
May 5, 2017
1,309
820
under a rock
my buddy had one in his garage for a few years.... it worked OK
but not worth the hassle for me.
You have to clean it regularly or it gets clogged up and flames out.
might work better with clean oil like Hokie said... but at that point your defeating the purpose of a waste oil heater.
I bought one of these last year.... works great.
I run home heating oil in it/offroad diesel. Sunfire-Heater-flyer.jpg
ruger1980
L4310 w/La682, L225
Oct 25, 2020
582
250
CNY
Many people, especially garages use waste oil for heat. Relatively cheap, but more maintenance involved and it does not work well with oil contaminated with coolant. It is kind of dirty though.
As far as blowing up your garage it would no more dangerous than a fuel oil furnace. BTU's should be at least as good as fuel oil if not higher.
5,329
There was/is a Youtuber that is "relatively famous” for making homemade waste oil burners of different designs.
I am currently saving my used oil in an IBC tote to make one………..one day……after my other 239,754 projects are done. ;););)
This guy is the guy I was talking about, he makes it look fairly easy.
Bountyhunter
40
9
Alberta
I have a commercial waste oil burner (clean burn) and absolutely love it. I clean it at 750 hours. Usually 2-3 times a year. I leave for a week+ in the winter and don't worry about it. The oil gets pumped into the supply tank through an automotive filter. It has a total of five "filters" and I've cleaned the last filter on the suction side , once in 10 years.. It heats the shop and the house and it's a lot less work than burning wood.
H
