Easier drain for water separator on a B2601
boost2525
17
Does anyone have suggestions on a replacement bowl (or maybe a modification to add a petcock) for the water separator on a B2601?
I'm getting an obscene amount of water in the fuel (I think it's condensation from the outdoor storage tank, but that's a bigger problem for another day). The OEM separator does a nice job and I have no real arguments with it aside from how difficult it is to drain the water. If the tractor is cold it's an easy job, but I get fuel all over my hands. If it's hot and I'm out in the field the engine bay is scalding, and I get fuel all over my hands.
I really like the design of the Racor separators (with the little plastic petcock on the bottom) but I don't want to bother with adding a second filter housing. Plus, replacing the OEM separator means giving up the automatic air purge lines. Ideally I would like to modify or replace the OEM bowl to something with a petcock.
Anyone have creative suggestions?
5,576
It sounds like you know what the actual problem is, so I would solve the actual problem before I solved the symptom.
However, I have heard good things about a device called “Mr Funnel” I think(?)
Apparently it will auto-magically take the water out of your fuel. (or more appropriately, in your case “take the fuel out of your water? ;) )
boost2525
17
Agree that I need to solve the root problem, but that involves purchasing a new storage tank and building a fuel polisher... Feasible, but I've got a half dozen projects in line in front of that.
That also feels like a nice winter project, was looking for something quick to help me drain the water off between now and the end of the season.
I'll research the Mr Funnel.
Joisey
Kubota L47 TLB
May 31, 2015
259
180
Wild, Wonderful West Virginia
I bought one some years back, and it does live up to its claim. I loaned it to someone, who thoughtfully loaned it to someone....who lost it. The problem I had was a gas station with old tanks that let water seep into the diesel fuel.
boost2525
17
MX6000 tractors have a factory water separator with a drain on the bottom . Very handy !
Just looked it up - yeah the bowl on that (#RD451-51360) is what I was envisioning.
I may have to rethink this though, I doubt I'll be able to retrofit any of these drain plugs because they all use a threaded tube that sits below the bowl. I was hoping I could just tap threads into the bottom of my bowl but then I won't be able to drain anything below the top of the threads. Bummer.
boost2525
17
Change the entire separator and mount ?
I considered that, but as mentioned in the first post - the B series has an air purge function with a return line that runs up to the fuel tank. If I change the housing I lose that feature (which has proven to be handy) - and I'd like to avoid that.
William1
BX25D, JD X754 AWS Mower
Jul 28, 2015
1,480
673
Richmond, Virginia
I got a 'Mr. Funnel'. While it trapped stuff well, it flowed horribly slow, not a surprise as only gravity to push fuel through.
I now run a water filter on my fill station. Also a 'high vacuum' cap on the fill station so it only lets air in after a long draw down, often having an under ambient air pressure in the tank, so no more breathing and condensation..
Not sure of the material and shape of the bottom of the OP's separator bowl, but I'd get a spare and see if you can drill a hole and add a spigot.
MapleLeafFarmer
Lots incl. B and L kubotas
Dec 2, 2019
1,202
1,195
E.
spit balling here
- is your bowl plastic?
- do you have room under the bowl to add a petcock?
if yes to both you could buy another bowl and take it to an good plastic welder or adhesive expert and get them to attach a nut to the bottom (plastic or other) and add a petcock that way.
edit: oops, should have read entire thread William1 beat me to this idea.
boost2525
17
I've been looking at pictures of the Racor 120AT and it looks like there might be a bleeder screw on the front of the housing (although I can't find any documentation that confirms that). Maybe I can throw an NPT/Barb fitting on that and toss a one way check valve in line on the fuel tank return line.
I might pull the trigger on one of these today. I'm willing to spend 30 minutes futzing with it this weekend in the name of science.
William1
Jul 28, 2015
1,480
673
Richmond, Virginia
So the funny thing is, I have a Goldenrod waterblock attached to my storage tank, but it doesn't seem to catch much of anything. Thinking about it though, it's on the pressure side of the pump, maybe I need to switch it to the vacuum side of the pump.
My filter (FilRite) is on the pressure side as well and that is the 'preferred' location, though I suspect the reason is it is easier for the pump to push through a filter VS sucking through.
Are you positive you do not have a condensation issue in the tractor tank? Store the tractor inside a closed building? Do not wash/spray water at the filler cap? Always top off the tank at the end of the day, not leaving it 1/2 full?
BAP
Dec 31, 2012
3,206
1,320
Buy yourself 1-2 of these and drop into your storage tank. If you are getting water in the tank, check the fittings at the top of the tank very closely to make sure that they are still sealed up. If you are getting condensation in the tank, then you aren’t keeping the tank full enough and/or you aren’t using the fuel out of the tank fast enough. If you only fuel up your B2601, then a storage tank is not necessarily a good choice.
boost2525
17
Update for any other B2601 owners... the smallest Racor filter is a perfect fit for our vehicles, with some creative angles on the fittings. It's Racor 120at (filter is labeled "R12T"). You can even use the factory mounting bracket and bolt.
You'll want to use 5/16" BARB x 1/4" MIP fittings. Use a 90 degree fitting on the filter inlet kicked at about a 45 degree angle, and a straight fitting on the filter outlet. The Racor has dual inlet / dual outlet, so you'll also need a pair of 1/4" MIP plugs to block off the unused ports.
I have not come up with a solution for the air purge system yet, because that appears to use a course thread metric M8 bolt (!?!?) and I think the fitting we need doesn't exist (M8-1.25 x 3/16" BARB).
That said... it's working perfect as a stop gap until I can solve my storage tank issue. It's catching water and I'm able to empty it without any tools, just by spinning the drain fitting on the bottom.
3,990
2,469
Don't the waterblock elements have to be changed when they get saturated?
3,990
2,469
I see some M8-1.25 x 1/4 barbs on eBay, Amazon, etc.
BAP
Dec 31, 2012
3,206
1,320
If you have water in your storage tank and it is getting into the tractor, then shorten up the feed pipe to the pump in the tank to get it out of the water. Water in the tank should all be on the bottom unless it gets stirred up.
