Kubota GR2100 Lift Cylinder
manvelman
Kubota GR2100
Feb 16, 2011
Manvel, Texas
I am hoping to rebuild the lift cylinder on my GR but am having difficulty finding dismantling instructions for the cylinder. The holding pin on the right side of the plunging piston does not have an access hole in the frame for removal so I am assuming Kubota want you to dismantle some framework.
Can someone give me some suggestions.
7,237
According to the cross section @Bee-Positive posted that is a single acting displacement type cylinder. Nothing to rebuild except the rod packing (4). Is your cylinder leaking externally?
11,043
That cylinder can be rebuilt.
On a scale of DYI = 1 and Professional = 10, I'd give it a solid 8.5.
It's not easy to disassemble or to get parts for it.
Bee-Positive
Nov 16, 2022
1,039
979
Amsterdam, NY
From the quick search on line they're God Awful expensive new for the size of them.
Any recommendations for venders with reasonable prices? EDIT - never mind, I type too slow.
Maybe worth finding a local shop that can do it for less than the cost of new.
7,237
One more time - is it leaking externally? If not there is norhing to rebuild.
Given Kubota's usual pricing model $335 for a new one seems pretty tame.
manvelman
Kubota GR2100
Feb 16, 2011
Manvel, Texas
Apologies for not being clear. The cylinder is leaking a lot. My question is not about rebuilding the cylinder but how to remove the cylinder from the mower. I am not able to remove The cylinder holding pin towards the rear of the GR.
11,043
Looks fairly simple to me?
Pull 2 ring Cotter pins, then remove 2 cylinder pins.
3,675
2,094
Are you talking about the rod end of the cylinder, which pins to the bell crank?
Disconnect the linkage from the bell crank and rotate it until the pin is above the frame; remove the pin.
