L2501 HST Treadle Adjustment
Mak65
L2501 HST
Apr 25, 2019
153
118
TX
I have a 2019 L2501, HST, with 300 hours. It’s not a speed demon but it seems lately it isn’t moving as fast as it once did at same RPM with or without load, especially in Medium (it has L-M-H range). I’m not talking bogging down or loss of power it just seems slower than before. WSM indicates top speed in M is 6.2 MPH. I clocked it using an app with a light load on front forks and an ever so slight rise. It indicated upper 3s to exactly 4 mph. At these speeds it seems even 1 mph is noticeable. Also, I don’t recall ever bottoming the treadle on the stop like I do now.
The WSM shows treadle linkage(s) but I’m not sure if any adjustments to any of it, and to what exactly, would increase the speed incrementally. I don’t want to throw off the pedal coming back to neutral for the safety switch, either.
Thoughts?
Michael
jimh406
Kubota L2501 with R4 tires
Jan 29, 2021
2,995
2,364
Western MT
Check to see how you are doing with the Hydraulic fluid and filter changes.
I doubt it's the linkage, but you could inspect it visibly and look for any nuts that have backed out or bolts that hold the plates are loose.
Also, have you noticed a reduction of max RPM?
5,580
Is your parking brake on?
(I am not being a smart ass neither, many, many, many people have accidentally left it on, some for extended periods of time ;) )
BAP
Dec 31, 2012
3,208
1,320
Thoughts?
Michael
How is your Reverse speed? Has that changed? A lot of times if the speed changes on the pedal in forward by slowing down because the pedal isn’t moving enough anymore, then reverse speed will increase.
Grandad4
Apr 5, 2016
447
195
Greensboro, NC
Is rear tire pressure low? If it's too low, there can be slippage between the tire and rim. If the engine/HST, etc. is all running normally but ground speed is slower than normal, that's another possibility..
JonM
Nov 29, 2024
293
699
wisconsin
if your like me i need to clean dried mud from under the peddle on a regular basis. this means i gotta pull mat up and clean in there really good. low hydro fluid level also contributes.
Mak65
L2501 HST
Apr 25, 2019
153
118
TX
Jimh406 - I stick to maintenance schedule religiously. It calls for air and fuel filter to be cleaned every 100 hours. Given my dusty area, I added the smaller, internal air filter and blow out the larger one often. I tend to change it out the external one every 75 hours or so. I’d have to check my log but probably changed it 4 times in the 300 hours. I change out the fuel filter every 100 hours, too. Actually time to do that as the hours are really just short of 300 hours. I haven’t noticed a change in max RPM But I’ll check that this weekend.
I changed hydraulic filters at 50 and 200 hours. I even changed the fluid at 200 hours. Level is where it should be in sight glass every time before I board it. Oil and coolant levels, too.
Run with scissors - not a SA comment as I was notorious for leaving the parking brake on from time to time the first couple of months that I owned it. Finally got in the habit of pushing the brake pedals before I start it now. Plus, if I forget, I notice the higher pitched whine when I first start to move and I catch myself quickly.
BAP - I haven’t really paid attention when I back up as I’m usually backing up to implements so not moving fast. I’m 2 hours from the tractor. I’ll try to test it this weekend though not sure I’ll notice since I don’t back up at speed. I can use the app to compare speed to what manual says it will do in reverse.
Grandad4 - I’ll check this weekend. Rears are loaded and pressure should be 14 psi. Thanks for the suggestion. Curious, if loaded and they slipped would I not see fluid leaks around rim?
JonM - my land is mostly sandy loam. Running into mud issues would be rare. Actually never had to wash mud off of it. Have to blow dust off it quite often, though.
Thanks everyone for the feedback. As mentioned, I’m 2 hours from it and will try some of your suggestions this weekend and will report back.
Grandad4
Apr 5, 2016
447
195
Greensboro, NC
Re. Slipping tires
Yup... loaded tires would probably weep if they were slipping unless there was a tube involved. If your tire pressure is adequate, that's most likely not the issue.
My Farmall M would weep fluid at the rims if the tire pressure got too low. While it never did field work when I owned it, I figured it would not be a good experience out there with low tires leaking CaCl all over.
Hope you get your situation resolved.
Mak65
L2501 HST
Apr 25, 2019
153
118
TX
Thanks Grandad4. I’ll be checking all these ideas this weekend - hopefully. It could all be in my mind. At least that’s what one of the voices in my head keeps saying. All of the others keep telling me to ignore it.
Mak65
L2501 HST
Apr 25, 2019
153
118
TX
Results of speed test - treadle on stop (yes, it’s not an accelerator pedal)
Tires aired, brakes off, 3-pt hitch down, loading arms (no implement) 18”-24” off ground, hydraulic fluid in range.
PTO (P) [~2000-2100] / Full (F) [~2350] RPM
High gear - 2&4WD - P 10 / F 11 mph
Medium gear - 2&4WD - P / F both 5 mph
Low gear - 4WD only - P only - fluctuated 2-3 mph
Reverse - medium gear @ P only - 2&4WD - 4mph
High and low seem to be about right. Reverse a bit low but I don’t work in reverse except occasional back up while mowing. Medium seems off though my app doesn’t give decimals so could be upper 5. Maybe it’s just me.
Oh, well, tractor does what I ask when I ask. It was a fun test though a couple of bumps at speed jarred the spine Thankfully, not once did I have to deploy the chutes to slow down. 😜
5,580
Just an FYI, I did a “speed test” when I first got my tractor, and the results were identical to @Mak65 .
Speeds were “clocked” using the wifes mini-van;)
(y) (y) (y)
Mak65
L2501 HST
Apr 25, 2019
153
118
TX
Bee-positive are you referring to the tractor or me?
Funny, WSM shows 6.2 for medium on HST.
Bee-Positive
Nov 16, 2022
1,228
1,117
Amsterdam, NY
US - all of us here on OTT. 🤪
Yeah, my post is from the Owners Manual, Specifications page 5.
Kubota's like my wife, reserves the right to change their mind, without notice, and for no reason.
