Pros and cons of snow removal options
kupitz
BX2660 with LA243 FEL and Front mount BX2750 snowblower/2763A heated Curtis cab.
Mar 28, 2016
139
New Providence, PA
Do you have a gravel driveway or concrete/asphalt? Im just curious how it works for you if you have a gravel driveway. I think even with the additional hookups for front hydraulics I don't think the l2501 could run it.
Asphalt, I don't think it would be useful on a gravel driveway unless you want to rake all your stones back in each spring!
Trustable
l2501HST
Jul 5, 2022
397
411
Haha yeah that's what I was thinking! I just wanted to check because maybe you knew something I didnt. Nothing like launching some rocks to the next county 🤣
jimh406
Kubota L2501 with R4 tires
Jan 29, 2021
2,939
2,337
Western MT
It turns out the best option is none. :D Well, it was for this year. ;)
I haven't plowed snow a single time with either my Polaris Ranger or tractor. I barely have even had to use a snow shovel. They say we might get snow over the next few days. Maybe none won't be answer for this year after that.
kupitz
Mar 28, 2016
139
New Providence, PA
It's an asphalt drive, I wouldn't recommend the rotary broom for gravel Disregard, not sure why it posted twice
muttbarker
Kubota L4060 HST, Snowblower, FEL, Rear Blade, 60" Grapple, 6' Bush Hog, Forks
Jan 24, 2022
96
71
Oakley, Utah
Did anyone mention a rotary broom? Admittedly I didn't read all 10 pages of the thread.....but I just got one and it is a GAME changer for me, wish I would have gotten one years ago. Greta for light snow low accumulations but also to "finish" what the plow or blower leaves behind. I have all 3 and can easily switch between them in 5-10 minutes using the front quick hitch. Pic of my snow removal arsenal! My drive is 1/4 mile log and all at grade with some spots hitting 14 grade angle.
14% or 14°? Units are important. 😂
I see that you use a front quick hitch for your blower. Was that a standard connection for your tractor / blower combo? Do you run that off of your front PTO? I have a Kubota L4060 with a blower and I would love to run it off a front quick hitch so I could swap implements but I have been told that can't be done. So, always looking to see what others have accomplished.
nbryan
Jan 3, 2019
1,425
944
Hadashville, Manitoba, Canada
My B2782B blower on my 2017 B2650HSD uses a made-to-model mid-PTO sub-frame and shafts for the quick connect, and if I wanted the angle-scraper blade and/or rotary brush attachment they're plug-and-play to hookup with the same subframe/hitch as the blower.
kupitz
Mar 28, 2016
139
New Providence, PA
The QH is part BX2751A and required for all three of the attachments. It is driven from the mid PTO, same as the mower deck uses. It includes a long drive shaft to connect the QH to the Mid PTO.
muttbarker
Jan 24, 2022
96
71
Oakley, Utah
Thanks - I wish Kubota offered something like that for the L4060. I love my snowblower but it is not worth using when all you get is light snow. I live in northern Utah and we had a terrible winter precipitation wise. I used the blower exactly twice during the season.
JonM
Nov 29, 2024
276
662
wisconsin
if your thinking about getting a blower now is the time to do it. either by ordering one or getting a deal on left over ones
dean22
New Jersey
MTO USED to have 'snow fences' on hwy 400 ( Toronto to Barrie,6 lane, major highway ), after they took them down ( cost saving idea... ) got an increase in accidents, especially between hwys 88 and 89. Had an Uncle Bob lived up that way, NEVER had snow on the highway..until AFTER the snow fences were removed.....
They had a 40-50 car pileup there few years ago..made a TV show out of it......
It is unfortunate that cost-cutting measures took priority over safety, especially on a major highway where snow accumulation can lead to such severe accidents.
Caseknife
L3130HST
Jun 29, 2026
NE Washington
I have a L3130 with a 7' FEL blade and off set back blade. Works good on my 3/4 mile lane. I do have to chain up all four and can't let the front blade float because I lose steering even chained up. If I watch when lowering the FEL and stop just as the blade touches down, it works great. We just haven't had much snow the last two winters, need that to change.
BiggB
B7100D, B2030 front blade
Mar 20, 2026
72
39
New York
A frequent question that comes up here revolves around "I have xxxxx. What should I use to remove the snow around here". Usually this results in a plethora of replies with each poster expounding on their own personal favourites. So I thought it might be fun and potentially more useful to condense the pros and cons of each approach in one thread.
Disclaimer: my own personal bias is towards snowblowing, because it seems the best solution for my own particular situation -- up to 18' of snowfall per year through a long wooded lane. So I'll start with the pros and cons of my personal favourite and invite you to join in with your perceptions.
Snowblower.
Advantages:
1. Lowest traction & horsepower requirements in deep snow. Instead of pushing and shoving a heavy load out of the way, a snowblower picks up the snow and tosses it off to the side. In deep snow, one can simply reduce the travel speed and move the snow with no additional stress or strain on the tractor.
2. No tendency to narrow the path over the course of the season. Since the blower tosses the snow well beyond the side of the lane, there are no banks falling back in beside the tractor after the blade passes or shoving the tractor towards the centre.
3. Discharge can be aimed. The combination of chute rotation and deflection allows the operator to place the removed snow anywhere within range of the discharge. EG: pile the snow to the side of an intersecting cleared path or away from the garage.
Snowblower disadvantages:
1. Highest initial cost. A snowblower costs more than a simple blade. In addition, some blades can be used for other purposes like moving dirt, whereas a snowblower is dedicated to one task only.
2. Higher maintenance requirements. A snowblower has moving parts that must be lubed or greased. Chains, gears and bearings eventually wear out.
3. Increased hazards: Snowblowers can ingest objects hidden under the snow -- frequently stones and rocks -- and then either hurl them with considerable force or jam in the mechanism, hopefully breaking only the shear pin. Operations are halted until the mechanism is repaired (it's as much fun changing a shear bolt with frozen fingers as it sounds).
4. Poor performance in wet, sticky snow. Some blowers are better able to handle this than others, but all blowers are subject to plugging under certain circumstances.
5. Slowest method of removing light snow.
Snowblower variations:
1. Rear mounted: Cheapest and often heaviest duty option, this hangs on the existing 3ph, is powered by the existing PTO and requires no special mounts or frames. Will fit a variety of tractors, opening up the used market. The tractor travels on the cleared path. BUT the operator has to twist around in the seat and drive in reverse. Can blow right up to a fixed object.
2. Rear mounted pull-behind: Similar to above, but the intake is on the tractor side so the blower is used while facing forward. Unfortunately, this means the tractor travels on the uncleared snow. Best suited to larger tractors with ag tires. Also, more difficult to get close to fixed objects. Operator can comfortably face forward while operating, although may require some twisting to observe discharge.
3. Front mounted: Most expensive. Tend to be lighter construction to reduce weight. Special mounts or subframes limit models each one can be used with, limiting used market. Requires forward-facing PTO, possibly at non-standard speed, or complicated drive mechanism. More prone to rudder effect (resistance to steering input) in deep snow. Can get right up to fixed objects. Most comfortable operation as the driver faces forward. Best view of discharge for the same reason.
4. Snowthrower (aka: single stage): Lightest construction, usually front mounted and offered for small low-powered (eg: lawn) tractors. These differ from a snowBLOWER in that the intake auger also throws the snow through the chute, instead of a separate impeller below the chute fed by the auger. These are suitable only for dry snow and plug very easily in wet snow. They don't throw the snow as far and may require a higher travel speed to throw it at all in light snow.
Blade:
Advantages:
1. Cheapest and most versatile option. An existing dirt blade can readily be adapted for use with snow, although a lightweight snow blade may not be up to the task of moving dirt.
2. Minimal maintenance. Other than a pivot for angling the blade, there's not much in the way of moving parts to maintain.
3. Fastest method of removing light snow. In fact, sometimes faster is better, giving the snow some momentum to help clear an existing bank.
4. Best way to move wet slushy snow. Blades don't plug up the way a blower can.
5. Best way to get close to objects. Front mounted or rear mounted, the operator can ease right up to an object (eg: garage door), drop the blade and pull the snow away.
6. May push gravel around and off to the side, but doesn't hurl it onto the lawn or through the neighbour's window.
Disadvantages:
1. Doesn't move the snow very far. This can be a huge problem where objects such as trees or fences border the path being cleared. After a few snow falls, such objects become anchors that prevent the bank from moving back and the path starts closing in.
2. Limited control of where the snow ends up. EG: leaves plow rows across intersecting paths that must be cleared.
3. Greatest strain on the equipment. Every action has an equal and opposite reaction; shoving several hundreds of pounds of snow out of the way means several hundreds of pounds of force pushing back. Particularly problematic if the operator tries to ram a frozen bank back further.
4. More likely to require multiple passes. Long paths and/or deep snow eventually leads to spillage past the leading edge of the angled blade, requiring either additional passes or smaller bites.
Variations:
1. Rear mounted. Most commonly seen with dirt blades. While the operator will spend most time facing forward, it may be necessary to twist around when plowing alongside obstructions. Blade and operator must be rotated backwards to push banks back.
2. Front mounted. Usually replaces a FEL bucket. May require 3rd function for angling. Operator faces forward in use with good visibility. Easily pushes banks back without reconfiguring blade direction. In fact, banks can be pushed in stages by initially lifting the blade and pushing the top first. Easy to drag snow back from buildings.
3. Snow pusher. Basically a blade with wings or perhaps a FEL bucket with no bottom, the sides help contain the snow within the confines of the blade without spillage or plow rows. Most useful for piling snow dead ahead instead of off to one side, up to the capacity of the pusher. Of limited use on long runs and deep snow. These tend to come in sizes suitable for large, heavy tractors with good traction and power. The wings limit how close one can get to drag snow back from a building.
Front End Loader
Advantages:
1. Perhaps the most versatile attachment for any tractor. It works with snow as well as it works with dirt. It can pick up loads of snow and cart it away to pile it anywhere you please. And since snow is lighter than dirt, you can fill the bucket to the brim with impunity.
2. Operator is facing forward not twisted around.
3. Possibly the best option for confined areas with limited capacity for piles of snow.
4. Great for heavy, wet, slushy snow.
Disadvantages:
1. Limited capacity. Unlike a blade or blower that continually move snow over a long pass, once the bucket is full you need to go dump it.
2. Limited ability to drag snow backwards away from objects. Even fully dumped, the bucket is angled away from the direction of travel and may tend to ride up on packed snow.
Variations:
1. Since snow is lighter than dirt, one can purchase a separate, larger, snow bucket to increase capacity and further leverage the investment.
OK: What have I missed about your favourite weapon?
I just got all needs covered 😂
BiggB
Mar 20, 2026
72
39
New York
Yea I saw that it’s on the back side I assume there was some deflection in the impeller it seems to run ok I’ll see more if we get snow this year.
