Adapting implements to Cat 1, 3-point quick hitch for bx-2680
Springer
BX2680 LA344S EA 55" Grapple, Stump Bucket 48 Box grader, Disc Harrow
Jul 21, 2021
102
59
Tiger, GA
I just got my Speech cat 1 quick hitch for my BX -2680. I just discovered that my implements are NOT quick hitch compatible. The lower hooks mount okay. It's the upper hook that is a problem.
I have a Dirt Dog 48" Box grader and a harrow. I'm looking for advice.
I'll post pictures when I get to my desk top computer.
Sawdust&Shavings
Apr 25, 2023
222
265
Stafford, VA
Older implements (as well as some newly made ones) may not meet these almost agreed upon dimensions,
Springer
Jul 21, 2021
102
59
Tiger, GA
Yeah, I'm learning that. The Box grader is close. The lower pins have a small tapered sholder that is causing the lower "hooks" not to close. I think I can grind about a 1/4 in taper to match it.
The Harrow is going to take a bit more creativity on the upper rod to top link.
I think I will need to shop around for some adapters.
PHPaul
Apr 2, 2015
1,311
1,656
Downeast Maine
www.eastovershoe.com
That's the sort of issue that has always made me question the usefulness of "quick" hitches. I can hook up any of my traditional implements about as quick.
The only real exception to that was a post hole digger. That thing was always a cast iron b!tch to hook up. Don't think a quick hitch would've helped.
Caden
1979 B7100
Apr 16, 2026
361
208
I agree with you there, I can hitch up the traditional way pretty easily without the extra weight or view reduction of a QH. But a brush mower always kicked me, especially if its not sitting quite level.
Shawn T. W
Dec 9, 2024
865
1,574
SW Missouri Ozarks
Maybe because I bought all new "QH compatible" attachments, except for the old rear blade I found out in the weeds when I bought this place ... But once adjusted and if there is no PTO shaft involved, I don't need to even leave my seat to hook or unhook ... If a PTO shaft is involved I just have to get off the attach that.
I like my QH, and bought a second one for my second tractor.
PHPaul
Apr 2, 2015
1,311
1,656
Downeast Maine
Two additional points:
1. I take some pains to park my stuff on level ground. It is indeed more difficult if things are askew.
2. This is modified somewhat by my top-and-tilt system. I can get "close enough" and adjust the lower arms and top link as needed quickly and easily. Some of the best money I ever spent.
Bearcatrp
Mar 28, 2023
1,403
1,015
Minnesota
I have to adjust my top hook on most of my 3 pt attachments. As long as your attachments can lock in the bottom hooks, the top can be adjusted.
Baby Backhoe Dirtworks
Kubota BX23S, GF1800, and looking to expand!
Jul 20, 2026
Swan River Valley, Manitoba
Thanks for this point PHPaul. My BX has very little adjustment available for the 3pt hitch, so it's a real pain hooking up without the quick hitch. Once I got good at it I could swap over in about a half hour on decent concrete, but was a sweaty ordeal involving pry bars and sometimes hammers. Now with my quick hitch I can drop attachments in the tree line and come back for them any time. 5 minutes tops swapping attachments now, though I've only got a 4' rough cut mower and a 50" rototiller. Both new from LandPride, so quick hitch compatible.
BUT my dad runs a B-series, which has loads of cool adjustment capabilities, which I could see greatly reducing the time it takes to swap attachments, while retaining the ability to use any random old piece of equipment, regardless of quick hitch compatibility.
Sawdust&Shavings
Apr 25, 2023
222
265
Stafford, VA
Now that you have a quick hitch this may no longer be needed…but telescopic loader arms significantly simplify attaching 3-point implements.
