B2320hsd (d1005) engine stop solenoid replacement caused engine to rev to top rpm
12acresoffgrid
B2320HSD (d1005)
Kubota 2320HSD (d1005)
Oct 26, 2024
I replace the engine stop solenoid on my b2320 hsd and now when I start it the engine revs up to maximum RPMs and has no response through throttle control. What did I do wrong when I installed the fuel solenoid / engine stop solenoid? I suspect it is not with the solenoid but with where the solenoid plunger connects to.
Has anybody had any experience like this or offer any expertise?
The part I replaced is number 4 in the attached photo
11,046
How did you determine the solenoid was bad?
How did you determine which solenoid you should use?
Where did you get the solenoid?
What happens if you leave the solenoid electrically disconnected.
Remove the new solenoid.
Set the two New and old side by side and take a picture of them.
Now run the tractor with the solenoid removed, what happens?
12acresoffgrid
B2320HSD (d1005)
Oct 26, 2024
I shall do that Sunday and report back. Thank you for your guidance
