Lawn correction implement
hoosier_chuck
B2401DT
May 16, 2026
Indiana
New tractor and new home - yard is in rough shape.
The yard is established, but full of weeds, ruts and divots. Thankfully it's flat, but it's still merciless to mow with a zero turn or garden tractor.
I'd like to eliminate the divots and the high/low areas. If I have to sacrifice the existing grass, I'm ok with that, it's more weeds than grass anyway.
My thoughts are a land sculptor, but the compact tractor world is new to me so I'd like to ask what implement I could use to tackle this yard and still use it in the future. I'd like to invest in something that I will continually use instead of purchasing an implement that will only be used once for this task.
Thank you
https://www.cs2photography.com/l1.jpg
https://www.cs2photography.com/l2.jpg
https://www.cs2photography.com/l3.jpg
https://www.cs2photography.com/l4.jpg
https://www.cs2photography.com/l5.jpg
https://www.cs2photography.com/t1.jpg
GrumpyFarmer
5,180
Good day.
Congrats on new machine and new home!
what do you consider a land cultivator? (Tiller, chisel plow, other?)
how large is the lawn / area you want to smooth over?
hoosier_chuck
B2401DT
May 16, 2026
Indiana
Sorry, I meant land sculptor
#40Fan
614
441
I'd vote to get a rototiller. You can smooth your ground up with it pretty easily.
Shawn T. W
Dec 9, 2024
786
1,414
SW Missouri Ozarks
I agree, a rototiller, add a land plane, then a roller ... Add grass seed at the end ...
KKBL
Jan 5, 2022
133
146
Girard, PA
We have a land plane, box blade, back blade, and landscape rake. A landscape rake could probably take care of the high spots and divots with a few passes. It seems to be the attachment we use the most often here for landscaping projects.
Bee-Positive
Nov 16, 2022
1,014
954
Amsterdam, NY
Roto tiller and landscape rake if not a land plane. I have more use for the landscape rake for my particular needs.
11,015
I use a spike tooth harrow and a landplane.
And no your tractor does not have enough oomph to run a sculptor successfully.
5,543
Thats not bad Bud, if you have bucks for all the toys, go for I say. For my piece of old field I just ran a roller behind the BX when I mowed, wasnt fast the deck set low took care of the big humps the roller squished everything back in to place. Is it a putting green, far from it but at least ya wont break an ankle walking across the yard
hoosier_chuck
B2401DT
May 16, 2026
Indiana
I like th
I like the thoughts of the spike tooth harrow - is there a 48" version of any of these? It appears this implement is intended for farm fields, ball fields, golf courses, etc.
I think this tool will be great if I can find one made for smaller properties and/or tight areas.
3,844
2,387
I'll throw my hat in the ring.
Depends on what kind of grass you have. Here in west Tn I have hybrid Bermuda, mostly. After living here a few years, we had a load (12 yds?) of washed sand dumped at the curb. I spent 2 weeks after work with shovel, rake and wheelbarrow spreading it - it looked like a beach and cost me a set of lawnmower blades. But by fall it was smooth and looked good, Bermuda loves to run in sandy soil.
If you have a cool weather grass that doesn't run, you might add some topsoil and spread it like @D2Cat suggested. You'll probably have to seed it.
