If you do please give a report. I just called for the price and it would save me about $1,200+ and would be plenty for what I need.I emailed them on that plate that mounts on the FEL. Wanted to know if it stays after removing the grapple. Said it stays with not ill effect on the FEL. Waiting on another reply on shipping time. Am leaning toward ordering one. Am running out of room for storing my attachments.
I was quoted $1600 to install a 3rd function for my 1880. Then another $2000 for a grapple. This grapple would save me allot of bucks. But still want a real review from someone who bought one and actually used it.It's still 'pinned on' in my eyes. Yes you hang the main body on the SSQA, but then you still have to install the rod and the two turnbuckle links to make it work.
3rd functions are so readily available now, and at reasonable prices (in my view anyway) there is just no need for these. Seems to be solving a problem that does not exist.
Just my opinion anyway, worth what you paid for it.
YOU can do it for 1/2 that most likely.I was quoted $1600 to install a 3rd function for my 1880.
Did you check it out?I will have to go check this out, only about 5 miles away
There are several under 300 lbs out there. EA and Land Pride and homestead implements for starters. I'm sure there are others out there.When someone releases a small grapple for the BX with weight under 300 lbs, I’ll do the 3rd function install and get it. These non hydraulic versions seem to limited and bulky.
Does it attach to a quick attach or to the pins? I don’t want to remove my quick attach.There are several under 300 lbs out there. EA and Land Pride and homestead implements for starters. I'm sure there are others out there.
