Oil pressure light and electrical charge light l3901
capnchuk
Kubota L3901HST
Jul 1, 2019
14
Belleville, IL
Was bush hogging. Tractor sputtered a bit then died. Restarted and ran for 20 minute. Happened 2 more times. On the last one, while key on but not running the oil pressure and electrical charge warning lights came on. Oil checked at proper level. Thoughts?
7,380
Perfectly normal and should happen on every start.
mdhughes
L3901DT
Dec 10, 2014
1,484
1,595
Ste Geneveive county, MO
Pull the hose going to the water separator and see what kind of flow you have coming from the tank. Make sure you clamp the hose off before you pull it from the water separator. You should get good flow out of the hose, if you don't, there is something at the bottom of the fuel tank that keep going over the outlet and blocking the flow. I have had this happen on my L3901DT.
