Flat Face Hydraulic Connector Help
EPIC
KX040-5
Jul 12, 2026
25
22
Florida
I am having a problem finding the correct flat face hydraulic connector to fit on my Kubota KX040-5.
I thought it was a #10 ORB, but even though it is very close in size it won’t thread.
According to local hydraulic shop it is a #8 British thread. This does thread but I am concerned that it might not seal since it doesn’t have a O-Ring at the base and instead relies on a bevel to seal that the coupling doesn’t seem to have.
The attachment is a hydraulic post hole digger, and the max flow is a little over 17 GPM. It has a Holmbury HQ12 coupler.
Can anyone please provide help on what fittings I need please?
MOOTS
MX6000
Jun 27, 2019
2,232
2,850
Canton, Georgia
Do away with the adapter and thread in directly to the orange pipe on machine.
3,133
There are TWO different types of “British threads”.
There was/is BSPP (parallel threads) and BSPT (tapered threads). This site describes the difference in thread types. To make it a bit more confusing they are now identified by DIN standard (G is BSPP). And used in the metric world but use inch sized threads!
You probably have BSPP threads on the tractor. The loader may have been built in Japan or in the USA so I won’t venture a guess what was used but if it is British it is probably the BSPP and needs a sealing washer.
Good luck.
11,198
Most likely BSPP fitting
7,322
Are you trying to mount a coupler on the pipe?
What does the other end of that male flat face coupler look like?
What is that plug you are holding in the black gloves?
It appears the fitting on the pipe is a BSPP female oring port.
EPIC
KX040-5
Jul 12, 2026
25
22
Florida
Thanks for collective wisdom, I appreciate the responses. I will check on BSPP fittings.
I was going to mount the flat face connector to the silver adapter on the pipe. Rational is that we have a lot of invasive pepper trees and the fear is a branch may rip the coupling and more parts between the couplings and the orange pipe means less chance the orange pipe is damaged… But inversely it could just provide more leverage to damage orange pipe?
Picture of other end of male flat face connector is attached.
Yes I am holding the plug with the black gloves.
It is my understanding that the excavator was made in Japan
Is the collective advice that I should just mount coupling to orange pipe directly?
EPIC
KX040-5
Jul 12, 2026
25
22
Florida
Ok, this is what all the BSPP fittings I found look like. I would expect a ORing on both sides of fittings not just one to get a good seal.
What am I missing?
11,198
The BSPP seals on the inside on the taper not on the O-ring.
The O-ring is on the O-ring boss side of the fitting, are your flat face connectors O-ring boss connections?
EPIC
KX040-5
Jul 12, 2026
25
22
Florida
Yes! That is my concern. The existing female coupling (on excavator) doesn’t have a taper for the adapter to seal to.
The flat face connectors I have are #10 ORB.
7,322
Now I understand your "taper" comment.
BSPP ports come on multiple types. Some are face seal using crush washers or one or two piece dowty washers. Others are o-ring boss that seal with a standard oring. The adapter in your pipe appears to be a BSPP o-ring boss port and seals just like an SAE o'ring boss. The 9006-10-08 adapter will convert it to a male SAE-10 stud termination. If your FFC is female SAE-10 its exactly what you need.
7,322
Oops - i reread your previos comments and I am still confused.
Is your FFC a male stud connectuon?
If so is it BSPP or SAE/UNF?
And what is the female thread in the adapter on your pipe?
