L5030 overheating
Bee-Positive
Nov 16, 2022
1,251
1,134
Amsterdam, NY
First welcome to the forum.
Need more information, my crystal ball is out for repairs at the moment.
Are you in Alaska plowing snow in the Brooks Range from the latest snow storm or in Utah moving dirt under the current heat dome? How long has it been overheating? What have you done, if anything, to determine the cause? How old is your tractor and what maintenance have you done (cleaned radiator, cleaned air filter)? etc. etc.
Not trying to be a wise guy but the more information you can provide the better the answers you'll get.
11,328
I got this:
Carnac the Magnificent
Because it's getting hot.
Rodledge
L5030HST
My Kubota L5030 HST started overheating last year while bushhogging my fields.
It spews steam and boiling water out the tube from the overflow tank.
Normally it runs at four to five bars on the instrument panel. Now it gets up to six of the eight bars and blows water and steam out.
Cleaned the outside of the radiator,
flushed the radiator twice,
replaced the anti freeze several times,
replaced the radiator cap,
replaced the thermostat,
replaced the water pump and still it overheats rather quickly when pulling a load like the bushhog.
Usually settles out at four bars when just low level idling or moving around the yard slowly.
It seems the next step is replacing the radiator, but I'm reluctant to put out $1,500 to $2,000 for a new one not counting labor which I usually do.
Only got about 800 hrs on the machine.
Need suggestions on what or how to test the radiators function!
11,328
Much better info!
First test is super simple, with it cold, open the radiator cap, top it off with coolant, leave the cap off and start the engine, look into the radiator for bubbles.
3,168
Is there a screen in front of the radiator that catches the large chaff? If so, have you cleaned it?
Bee-Positive
Nov 16, 2022
1,251
1,134
Amsterdam, NY
Thanks Rodledge
Follow the advice above, these guys know their stuff.
Good luck and let us know if it works out, we can proceed from there.
JonM
Nov 29, 2024
294
708
wisconsin
make sure your fan belt has the correct tension. tensioning that belt is part of routine maintenance. if the fan belt is loose it will over heat
Rodledge
L5030HST
Much better info!
Much better info!
Much better info!
I guess I'm doing this right - my first response on a forum!
The weather has been quirky in Alabama this year with on and off rain and heat so I haven't gotten back to fixing my problem until now. Last evening I followed your instructions and observed for bubbles None seen. The radiator and water did heat up and after about ten minutes the temp gauge got up to four bars. So I sent my grandson to the field to bushhog for about 20 minutes. The gauge was at four bars (pretty normal and I didn't hear any boiling of water). The air temp was about 80 and the grass was high and somewhat wet from an earlier rain. I will add that I have mostly water and some radiator flush in there at the moment and I had used a air pressure nozzle to clean out the radiator earlier in the day. I didn't think that I got much dust or debris out but it must have helped. Today we checked for bubbles again and at about 4 to 5 minutes got a few bubbles probably near the time the thermostat opened. At 10 minutes the temp gauze was at four bars. Will try do some more field work later in day.
11,328
Do not keep running it it with radiator flush in it.
run lots of water through it to clean it all out.
Put 50/50 coolant / water mix in it and see what it does.
Shawn T. W
Dec 9, 2024
868
1,576
SW Missouri Ozarks
Yeah coolant tends to keep engine cooler than plain water, not only does it have a higher boiling point, but it is "wetter" as in it makes better contact with the hot metal and transfers the heat from the metal to the coolant better/faster ...
