KX040-4 vs KX 121-3
jeffthogmartin
TN
Hi i Need some advice for my first excavator purchase.
I am looking at purchasing a used mini ex and I am torn between two models at a local dealer.
2020 Kx040-4
2012 Kx 121-3
They are nearly identical in hours, both abround 1800-1900hrs, both are tight machines in good condition, both have quick couplers both are open canopy machines and both are around the same price.
The 121-3 has a 6 way blade and the 040-4 has 4 way (the blade doesn't matter much to me tho)
I will be using it for development of my 17.5acre mountain property in tn. Things like installing septic, digging trenches for drainage, moving rocks, clearing timbers, collecting firewood digging out for additional outbuildings etc.
I am torn between the two machines bc my gut is leaning toward the older 121-3 due to no emissions and dpf and more sinple to fix myself should I have to ( I am reasonably handy). But my logical brain is saying to buy the newer machine bc it's 8 years less wear on all the components.
What do you all think? Anyone have any input? If I were to resell in 5-8 years which would be easier to resell? Any and all advice/help is welcome and greatly appreciated🙂
JasonW
886
588
Al
If the hours are similar the wear and tear should be similar if equal taken care up.
I’d vote towards the 121 due to the 6 way blade.
Does either one have a thumb?
5,502
Given the fact they are so close in almost every way, I would personally go for the older one.
I am also a DIY’er and work on my own stuff (almost to a fault); So the less computer/emissions stuff, the better in my opinion.
Full disclosure, I have never owned, worked on, nor sat in any of those machines. My opinion is just from a "general viewpoint”.
I tend to like simpler’er machines in general….As a matter of fact, it is the reason I decided to get a 2501 instead of a higher HP machine, and I still drive my 21 year old Cummins 5.9l.
Did you take any pics of them you could post?
Thats my .02…Good luck sir (y) (y)
jeffthogmartin
TN
Thanks for your reply! This is exactly my train of thought just helps to have others opinions as the world of excavators is new to me.
I do not have any pics but here are the listings if you'd like to check them out.
Thanks again!
Bee-Positive
Nov 16, 2022
1,134
1,056
Amsterdam, NY
The KX040-4 looks like it's been left out and beat up a bit. May not affect the mechanical soundness but is that an indicator of how it was treated? Just an observation.
L35
Jun 13, 2010
713
831
CT
I guess the only downfall to the older unit is end of life (Kubota supported) components will come up sooner.
With the newer if emissions are a concern that can be dealt with through the aftermarket.
JasonW
886
588
Al
If the blade doesn’t matter for what you need you can find an older model with the 4 way blade cheaper.
That said if the 6 way blade model is still available in a few months I’m seriously considering making the trip and buying it.
5,502
Along the lines of what @Bee-Positive was eluding to, I also question why a 6 year old model is sellling for the same price as a 14 year old model?
Is there some difference(s) that I am not aware of???? Could be….I have never shopped for one.
There is too much that I don’t understand to give an “informed opinion” though.
I just tend to like “older and simpler” I guess, but that may not be a “plus” for some people as @L35 mentioned about parts.
🤷‍♂️ ………..wish I could be of more help.
Good luck!
L35
Jun 13, 2010
713
831
CT
Good luck!
Older low hour machines in good shape demand a premium because of lack of complexity.
BAP
Dec 31, 2012
3,190
1,306
The description for the 40 says that they are putting new tracks on it which is quite a bit of money which is being passed on in the cost. I would want to know what other undercarriage parts they are planning on putting on. Are they changing the sprockets? The rollers both top and bottom? How are the tensioner pistons? How is the alignment? Do the drive motors leak? Undercarriage repair is expensive. For the 121 I would be going over the undercarriage very carefully to check for issues.
JasonW
886
588
Al
I called about the 121 this morning, it’s already sold.
The description didn’t match either, it was listed as a one owner but during the videos you can barely hear the guy talking over the machine it was owned by duke power bought by them they installed a thumb sold to a farmer a few years ago who traded it back in and the whole time the hour meter wasn’t working? But they state it’s working now?
Still probably not a bad deal but I don’t see how that is a one owner?
OP they also have a KX057 for the same price as the 121 was. Which would be better if you have means to transport it, or if you only plan on using it at your property. I’m looking for one that will fit inside my dump trailer.
EPIC
KX040-5
Jul 12, 2026
25
22
Florida
KX057 isn’t very likely to fit into dump trailer unless it’s very big with heavy axes.
Even if you can actually get it in the dump trailer, most likely you won’t get the balance right.
-m59-
m59
Aug 27, 2025
SouthWest
I bought a KX040-4 with 1500ish hours. Good solid machine.
It is located on property in the rocky mountains.
About 20 acres more or less.
I am in an area with untold numbers of ancient river rocks in the ground.
These rocks rolled here millions and millions of years ago.
I dig and get about 60% rocks and 40% dirt.
Many of these rocks exceed 1000 pounds.
A few have been about 3000 pounds.
The KX040 has been able to maneuver these rocks around.
The tree stumps that are freshly dead still have very strong roots.
The 40 with use of a root ripper has been able to handle most of them.
Sawdust&Shavings
Apr 25, 2023
222
265
Stafford, VA
For those larger rocks and tree stumps, three wraps of decord will make gravel out of the rocks and take down a tree (or stump) with ease…the explosion, noise and spent pieces flying everywhere, you get for free...the smile on your face: PRICELESS.
racerboy
L6060 Cab, 1055 loader, grapple, BH92; RTV-Cab
May 10, 2021
247
226
NJ
I just bought. New KX-033-4 last month. I specifically went with that machine due to its size and ability to move it between properties. I never owned a mini-ex before (I traded in my BH92 as part of the deal) but as Sawdust mentioned above, it is pretty amazing what you can accomplish with these machines, even for a complete amateur like me. :rolleyes:
