Please help. My husband passed away and although I'm kinda technical I am still missing something. Paying Messicks so much in multiple shipments I can't afford diesel. (But who can?) Please direct me to the correct post if this question has been asked before.
I only use the Belly Mower on my B7800. No other implements are attached. Hydraulics seemed fine last week. Now control lever is floppy and my mower is on the ground. I noticed the spring and lock nuts were missing from the feedback bar. (Thanks for all the help the past year, I've read a ton of forum's. You guys are much appreciated.) I ordered replacements and slid them on the bar and placed the screws as far as possible on the threaded part of the rod. Everything else seems connected ok. Hydraulic fluid is good and the knob between your legs is almost all the way on. (Behave.) No change in the arm or movement of the hitch. The feedback arm moves but does not engage the spring. The interlocker assy is still tight and were it was prior. Pin spring is still attached to lifting arm and feedback arm slides up and down - just never touches the spring or moves the hydraulics. Please tell me I don't have to take the tire off.....just shoot me instead.
Thank you so much,
Jessie
Thank you so much,
Jessie
