LX2610 Air Conditioning
cthomas
LX2610 HSDC
Jan 1, 2017
866
576
La Farge Wi
After putting up with weak air conditioning in my LX2610, I decided that the TXV needs to be replaced. While I have the roof off is their anything to insulate to roof? I know about tinting the windows, but, sometimes operate in the dark. The TXV lowered high side by about 75 psi(in no way scientifically measured) and have not shoved a thermostat up the duct(keep forgetting it at work). my high side was getting in the 350ish zone. Also Kubota wanted almost $500 for the Denso TXV, but was able to cross the part number to a AP air TXV for $45. Also has anyone installed coolant heater core bypass valves?
sardillim
b2650
Nov 24, 2019
130
68
Easton
I never thought about insulating the roof I did dynamat the floor and I have a little better cooling and a little quieter maybe dynamat at the roof?? I'd be curious to see if you notice a difference
Dustball
2016 B2650HSDC
Sep 15, 2023
521
384
Hudson, WI
Part number interchanges
BAP
Dec 31, 2012
3,194
1,307
Just cut your heater line somewhere near the engine and put in a shutoff valve. Can be just a ball valve with 2 nipples on it. Close it in the summer and open it when it gets cold. Put many of them in various tractors and other equipment over the years.
Donystoy
Dec 10, 2013
738
381
Binbrook, Ontario
Just wondering how you determined that you need to replace the expansion valve. Have you had poor cooling since purchasing the tractor new? Mine is a 2022 model with about 450 hours and the A/C works fine.
3,774
2,181
dealer was did the CCND and NPF.
Why post abbreviations that have a large number of results rather than just type the word?
If either CCND or NPF is searched, each comes back with pages of results that have nothing to do with air conditioning at all.
