Cleaning tractor loader/excavator grease joints.
Gaspasser
L6060, FEL, forks, BB, rake, snowblower, KX033 mini-ex, dump truck, splitters.
Dec 16, 2023
474
766
NH
sweetbreezefarm.com
When greasing my zerks, I clean off the old grease that has oozed out of the joints and accumulated crusty dirt first. I go through multiple rags as the old grease can be quite tenacious and thick. Was wondering if folks use a solvent/spray that is paint safe to assist in cleaning off the grease. Thanks.
#40Fan
674
499
I personally don't do anything with it until the machine gets power washed. I do like keeping things cleaned and I wash more often than most people, just not enough that I don't get some grease accumulating.
4,269
Power Wash…then a gallon can of WD40 and a large pkg of paper towels. (Diesel fuel would likely be just as effective and cheaper…who’da’ ever thought that could one-day be suggested…. 🥴 ..)
(I use WD40 in a 5 gal bucket of water instead of soap when washing some vehicular things… Results in a just-waxed clean vehicle with lubricated weatherseals and door-hinges etc. etc… especially good for keeping bare aluminum clean and preserved…)
6,895
IMG_0142.jpeg Couple times a year I brush it off by driving through stuff like this for a few hours bush hogging.
Trash Panda
L2501
Feb 18, 2022
295
279
Wyoming
I leave the grease on all my equipment until it falls off, or it gets a pressure wash.
I always get on our employees and tell them that dirty pivot pins are cared for pivot pins.
7,386
I pump in fresh grease and get to work.
4,269
The mechanic at the tractor-dealer was overheard to say (when a dirty/greasy tractor was being unloaded for service) : “Well… at last… a tractor that’s owned by someone who TAKES CARE of it!”
5,582
I started using mineral spirits…but then got bored/tired/disinterested/squirreled and now I just “grease and go”.
I will get back to it one day….I promise…... :unsure: ;)
Gaspasser
Dec 16, 2023
474
766
NH
sweetbreezefarm.com
Yes, it is incredibly tedious and time consuming to clean all the joints first. Demotivating. Seems many just grease and go and if that means more motivation to grease more frequently, better than not greasing frequently enough. Thanks all.
Caden
1979 B7100
Apr 16, 2026
375
214
I don't use a solvent but I wipe them before and after. If you clean them after greasing, there is less for dirt to stick to during use.
B2710
MX6000HSTC, KX-040, RTV1100, L3300F
Dec 13, 2011
61
37
NW Tennessee
If I use anything, it is WD-40, usually carry a couple of rags when greasing, wipe before with one rag, pump some grease till I see it coming out of the joint and wipe again with a clean rag...
JonM
Nov 29, 2024
294
708
wisconsin
i only barely clean the grease just enough to get to a zerk or if a glob of old grease is about to fall off.
Joisey
Kubota L47 TLB
May 31, 2015
261
185
Wild, Wonderful West Virginia
One of the best things I've found to clean up zerk fittings and general grease is a tube sock stretched over a hand covered with a vinyl glove.
The socks are mostly synthetic, so they are no good to soak up oil, but have enough strength to remove stubborn grease and wipe zerk fittings before and after. You can rotate the sock 3 or 4 times to give you a new wiping surface, then peel off and throw it away. It takes 4 to 6 socks to grease/degrease my L47TLB.
