L3560 FEL drift and shop HID to LED conversion
10,950
Beebad
Kubota L-3560 HTC
Oct 12, 2024
53
11
Northern New Hampshire
I know now that the new bulbs are not the issue…the problem lies with the capacitor or the ballast.
10,950
Well that a good thing.
Kill the power and open the fixture up and take pics.
It might be fairly simple to bypass the ballast and put in LED's.
10,950
That is 240v.
Pretty stupid for them to have run all the wires in red, makes it really tough to keep everything straight.
All the red wires are HOT 120V on each lead and a combination of 2 is 240V.
Good thing is you won't need to change anything in the relay box to make it work.
3,817
2,376
That is 240v.
I wonder what the 4th relay controls.
Good find on the HID replacements. I'd warn OP to confirm the socket and bulb size. The description from 1000bulbs is medium base and the Home Depot is mogul base, which is what I've seen in my extremely limited experience with HIDs. There is a mogul to medium adapter available if necessary. And they all seem to accept 110-277v power.
Also, maybe this was your point, some use the ballast and some require bypassing it. Personally, I'd bypass it - I don't like leaving unnecessary components in, just more potential failure points.
3,051
Too curious to not ask…
What is the one white wire (not bell wire) in the lower left of the box for? It looks like it was part of the red wire pull but just dies in the box. Does it go anywhere?
Beebad
Kubota L-3560 HTC
Oct 12, 2024
53
11
That is 240v.
four light banks, four switches
3,817
2,376
That is 240v.
Some wire numbers and a schematic would have been nice.
10,950
That's a neutral for the transformer.
