Removal of Bent Holder Lift Link in B4200D
B4200D-Oldy
Kubota B4200D, B1620 Loader, RC44-42 Mower, Mold Board Plow, 7-Tine Hay Fork
Jul 18, 2026
New England
Newbie here! Anyone know what the usual procedure is to remove a Holder Lift Link assembly (Pt #76502-51192) of a mid mount mower in an older Kubota B4200D tractor? This is the linkage that lifts the mower deck. It looks like the linkage bar is slightly bent, so it won't rotate in the horizontal tube of the assembly meaning the lift tabs can't be moved. So even though I've detached it from the transmission case and loader subframe, I cannot wiggle it out from between the subframe. it looks like I could remove the subframe, but I'd like to avoid that, unless that is part of the normal removal procedure. I was hoping to take this part to a shop where they could bend it straight so it will rotate again. Any ideas.
Bee-Positive
Nov 16, 2022
970
926
Amsterdam, NY
I've been wrong (several times) before but looking at the parts diagram I don't believe there's anything that "rotates" in the tube. Looks like it's all one piece and the linkages rotate on the ends. There's only the one part number for it and no indication of a separate shaft running through it. Not sure if you could get enough leverage on it to bend it straight without taking it off the tractor.
As to getting it out - it appears to put the FU in FUN. Hopefully others here with more experience have an easier solution.
B4200D-Oldy
Jul 18, 2026
New England
Well, here's an update if anyone is interested...
Looks like I am going to have to support the front loader somehow, and then disconnect the front loader uprights from the subframe (there are two clevis pins) — my goal is to not have to disconnect the hydraulics — and then disconnect the front and back mounts of the subframe so that I can lower it enough to remove the holder lift link assembly. Then I can have a local tractor shop press the bent rod and assembly straight and hope it will rotate. Fingers crossed.
B4200D-Oldy
Jul 18, 2026
New England
Thanks for your reply Bee-Positive! ... The parts diagram doesn't detail the way the linkage functions. Tabs on either end of the rod would need to rotate in order to raise the mower deck, because the main body of the holder is bolted to the subframe and transmission case. It's too bad that the linkage tabs are welded to the ends of the rod on both sides such that it is not removable (which is why it's a single part). If they were removable somehow, the rod could simply be pushed (or hammered) out of the holder tube and straightened. Kind of a design flaw. Sigh!
B4200D-Oldy
Jul 18, 2026
New England
Looks like this tractor has quick disconnect couplers on the loader hydraulic lines which means minimal fluid leaks. So I'm going forward with removing the loaders as directed in the manual — moving the bracers to their standing positions. Learning more each day. I did learn that removing the rear subframe mounting bolts allows the differential gear oil to dribble out. Need a gallon of UTTO or UDT universal oil on hand to top up.
3,645
2,063
Is the fluid leaking out of a bolt hole?
