Skid Shoes for the BX2816 snowblower
Denny Smith
Kubota BX2380 with snowblower (2816), front loader (LA344S)
Nov 19, 2025
23
Michigan U.P.
Got a BX2380 with the front-mount snowblower, and a real long uneven gravel driveway. Looking at SBS Armor skid shoes to get my scraper blade higher off the ground than the factory ones. Having 1 or 2 " of snow left on the ground is no problem. Anyone know which of the SBS skid shoes might work on the 2816? Also, trying to avoid for one more season putting on a schedule 40 black pipe on the scraper blade, and am thinking the newer skid shoes might help me avoid that. Thoughts from the real worls? As always, appreciate y'all....D Here's their website:-> https://snowblowerskids.com/product...blower-skid-shoes-fits-slot-spacing-set-of-2/ Also, by raising it up a bit, and staying in float mode, am I setting myself up for drive-train damage or such on the blower or the K-connect?
10,986
Just measure the spacing on the bolts on your blower.
The set you put up shows 1" and 3" spacing
They have other sets based on spacing of the mounting bolts.
Having the blower set that high should not affect the operation adversely.
Denny Smith
Nov 19, 2025
23
Michigan U.P.
Thank you brother.
Denny Smith
Nov 19, 2025
23
Michigan U.P.
Thank you brother.
Well y'all, came across a vid where the dude makes his own skid shoes out of oak or other hardwood, 5 1/2 " tall, about 1 foot long, and they lasted 8 years. It keeps the scraper blade about 1" full inch off of the ground for gravel driveways, and simple as heck to make. Gonna' try that first. Bet it works. Best....D
Bee-Positive
Nov 16, 2022
985
938
Amsterdam, NY
As a hobby woodworker I'd be interested in seeing pictures of your build as it progresses as well as the final product. We love pictures!!!
Bearcatrp
Mar 28, 2023
1,364
992
Minnesota
I like those. Need to measure my SB1051 to see if they will fit.
Denny Smith
Nov 19, 2025
23
Michigan U.P.
I'll do ya' one better: here's the original vid. While it isn't on a tractor snowblower, I bet the principle still works. I'll be using a piece of hickory, with a Janka past 1600 if memory serves--that's pretty hard. Here's the vid->
07wingnut
274
123
Clearwater, BC, CA
Or you could go down this route. The caster wheels are adjustable to set the snowblower height from 0 to about 6 inches. Works well on a gravel driveway that hasn't got a coat of frozen snow on it yet. snowblowercastor1.jpg snowblowercastor2.jpg
Bee-Positive
Nov 16, 2022
985
938
Amsterdam, NY
Pretty simple fab. Not sure they would hold up to the weight and stress of a front-mount through. Maybe if you made 'em real beefy.
Denny Smith
Nov 19, 2025
23
Michigan U.P.
I was thinkin' that too. As hard as hickory is, maybe. So, I might splurge and get the Armor Skids--they're not too expensive, do the same thing, and bolt right on. Thx for the ideas!
Bearcatrp
Mar 28, 2023
1,364
992
Minnesota
The wood could work for a little bit but won't chance one breaking in the middle of snow plowing. Will be ordering the armor skids. As for the wheels on back, I have a set on my rake. Don't think could handle the weight for long periods.
Denny Smith
Nov 19, 2025
23
Michigan U.P.
Appreciate the input, and I think you've got some good points, and experience. Armor gonna' get back to me today or tomorrow, and I'll make a decision then. Best...D
Mowbizz
Bx25d
Aug 19, 2021
612
357
I just use the factory skids on my BX5455HD blower…set them all the way down and blow my gravel driveway easily. I sometimes take mine off “float” for challenging areas and have had no trouble for 6 yrs. On a side note, my original skids wore down unevenly so I grabbed a new set for this coming winter!
Denny Smith
Nov 19, 2025
23
Michigan U.P.
Gotcha'. Mine just can't get low enough. I believe their max heighth is 3/4", and I"m lookin' for for 1 or 1 1/4. Out in the woods, driveway isn't the flattest in the county either. However, I noticed in the manual for the 2816 "IMPORTANT" and it states pretty strongly not to use the blower in anything but float or "severe damage" could be done to a bunch o' stuff. I too raise mine here and there, which they say is ok, but not for long. Anyways, the dang thing needs more height for the driveway a a few grassy areas. Thanks!
Mowbizz
Bx25d
Aug 19, 2021
612
357
I don’t have the K connect system on mine it’s the quick hitch that hangs on the front of the tractor then that coupled with the blower. It’s an older Bx25D
Bee-Positive
Nov 16, 2022
985
938
Amsterdam, NY
Hey so hmm i like kubota and all but ive been buying chinese brands recently
this snow blower is quite good and inexpensive
Hey Lickytongue welcome to the forum.
I'm not sure what tractor you're using that unit on but it requires more GPM flow than a BX can supply, at 1,000 lbs. might be too heavy for a BX, and $5,000 being inexpensive is relative to each individuals particular circumstances. EDIT: And would require a 3rd function to be installed if not already.
Besides the original poster already has a snow blower, just needs new skids.
Denny Smith
Nov 19, 2025
23
Michigan U.P.
Thx. So I wound up goin' with the ArmorSkids CUT-24 series. Pricey, but for what I'm snowblowin', just right. Gotta' drill one more hole, but, no worries. Just don't want the expensive repairs on that unit, and I do all of my own maintenance religiously (chain tension, auger lubes, k-connect lubes, all of that stuff).
