How to "finish" loader bucket after repairs
Johnboy00
2007 Kubota B7510
Dec 25, 2024
Western Wisconsin
I have a 48-inch bucket off of a LA272 FEL that is going to be repaired ( bent cutting edge, side panel) and I will have them add a couple of chain hooks. Is it reasonable to ask the shop to get it to a "paint-ready" state and what does that involve? If that happens, what should I do to protect the new metal from rust? Prime and paint with rattle cans? Powder coat? If not, what should I do to prep the bucket for new paint? I'm very new to this aspect of tractor ownership so I'd appreciate any advice to get it to a state where its going to last awhile. BTW, I didn't do the damage to the bucket as I bought it that way. :D TIA!
11,199
Prime and paint, nothing fancy as you'll buff off some of the paint with normal use.
airbiscuit
Mar 18, 2021
413
476
NW WI
I find Implement paint to be pretty durable. Recently, I had a metal shelter that needed painting. I bought a cheap cordless sprayer - not expecting much. I was super pleased with how well it worked. It's cheaper to buy paint by the quart or gallon than rattle cans.
jimh406
Kubota L2501 with R4 tires
Jan 29, 2021
2,977
2,357
Western MT
I'm not sure why it wouldn't be paint ready if it's being repaired. They may also paint it for you. They just need to make sure the yuse the right version of Kubota Orange for your tractor if you want it to match, but black or grey would probably be ok as well.
selftot
L3400
Aug 6, 2025
116
142
Vancouver Island
My welder always does an initial coat of primer before i get stuff back. Prevents rust from starting.
I cover it with Farm & Implement paint - usually rattle can.
John T
2017 BX23S 385XP Miller211 1952 Panhead Orange Ludwig 4 piece
May 5, 2017
1,344
865
under a rock
No prep necessary.
It's a Dang Tractor!
my favorite Orange is Rust-oleum 280142
$7.00 a can.
matches close enough.
7,323
I assume its already painted and unless they do something funky to remove the old paint thats all it "needs". Pin it on and put it to work.
4,238
snoeproe
BX23s
Feb 19, 2026
15
Powder coating a bucket will require a curing oven large enough for the entire bucket. Not an option most of the time. Primer and paint to match Is the best way to go. Don’t over think it. Put it to work.
