Slow leak in front tire
fruitcakesa
M4 071
Oct 26, 2010
891
306
Cavendish Vermont
Having trouble locating the source. Tried spraying it with water but it must be so slow that it’s not noticeable. This is a 320x70r24 radial and heavy as a MF. Any suggestions, I don’t necessarily want to tube it if I can repair it in place.
10,963
Use a good quality stop leak.
Saved me many a headache with the unfindable leakers. ;)
jaxs
B1750HST
Jun 22, 2023
1,065
803
Fix-a-flat has it's place but can also make things worse in some cases. Just how heavy a MF is can be subjective. 3320x70r 24 is a hand full but no problem with right tools and equipment. If same tire is loaded, it is even heavier but most important, makes fix-a-flat worthless. I turn my own wrenches but imo, letting tire shop handle tires is money well spent.
Bee-Positive
Nov 16, 2022
974
929
Amsterdam, NY
I had a slow leak for months that was driving me crazy (I know - short trip 🤪).
Did exactly what you're doing trying to find the leak.
Turned out the valve stem wasn't tight but never showed any bubbles.
Tightened it up and now no more leak.
Hugo Habicht
G1900
Jun 24, 2024
1,540
2,228
Ireland
I had a pin hole at the weld in a brand new rim recently. Also no bubbles because in my tub I could never dip the whole wheel in fully and the air was escaping through the centre, not at the tyre or the edge of the rim.
jaxs
B1750HST
Jun 22, 2023
1,065
803
Proper inflation is often below 20psi, boosting pressure to 50psi while testing helps soap bubbles show up better.
LFP57
LX2610 Land pride QH 10, BB1560, EA 55" Wicked Grapple, Top n Tilt, Wicked T
Sep 21, 2021
161
78
Any people have good things to say
Many people have good things to say about LiquiTube
5,262
I have the "Kubota Brand” stop leak in my fronts.
However, I installed it as “preventative maintenance” . Therefore, ironically enough, I can’t tell if it really works…OR….. Do I not have a leak? 🤷‍♂️ :unsure:
“I see said the blind man, as he picked up his hammer and saw."
“If a tree falls in the forest, with no one around, does it make a sound?"
“If my Uncle had wheels, would he be a wagon?"
jaxs
B1750HST
Jun 22, 2023
1,065
803
Water can find normal leaks but you must use soapy water for slow leaks.
Mix dish soap in water then use paint brush to test bead and stem. Block tire up off ground , rotate and brush between treads. Sidewall and wheel defect would be my last suspects but brush with soapy water can find those.
5,510
I had the same problem, went the stealer and the kid be hind the counter handed me a couple bottles of SLIME, not my favorite thing but I ll try anything once,,, put it in and mowed for a couple hours. That was several years ago never had to air them up again
